We have an AIWA VX-D2120 TV/Video Combi, The first digit of the PIN is a 1 but 1 does not function on the remote. We need to open up the security and change the pin code without using the 1 on the remote.
    Genius:
  • 1,622 Answers
Common faults are: some buttons not working, not working at all, corroded battery terminals. Often buttons are sticky because of some dirt accumulated over the years from the sticky little hands of your kids?
The hardest part of repair is often to open the covers. You do not need much experience in electronics repair to repair a remote. Also it is perfectly safe as there is no way to get an electric shock as they work with batteries.
step 1Test your remote with Digital Camera
Check your batteries first or buy new batteries. Once you have good batteries, you can test with a digital camera by pushing the buttons and having camera on and pointing to the infrared led. You should see red light if the remote is working. If no light comes up you obviously have a dead remote but do not despair and proceed to the next step
step 2Open the remote control but there is a catch or a few catches.
Remove the screws if any. Sometimes screws may be hidden under a sticker or rubber feet. Often there are no screws at all but just plastic catches hidden so you have to be clever to open it without breaking the case. Use something blunt and flat to click the covers open. This is often a challenge but should not be too difficult.
step 3Take a picture of every phase so you remember how to re-assemble
Since you are using a digital camera you might as well take pictures of the disassembly so re-assemly will be easier.
step 4Pull everything apart
Did you take a picture of the keypad layout? Sometimes keypad is just one rubber membrane but sometimes the keys fall away like pieces of a Lego puzzle. And if the buttons are marked with numbers and functions you may struggle to re-assemble them in right order? Use a small plastic takeaway box or similar to store the bits so you don't lose parts.
step 5Inspect the circuit board and repair dry joints
Remotes are often dropped on the floor and may develop dry joints on the battery contacts or circuit board. Inspect the contacts and circuit board under good light with a magnifying lens or if lucky you might have a microscope or just a very good eyesight? Solder all suspicious joints. If there is a sign of water damage you can use methylated spirits and toothbrush to...
step 6Wash the covers and the buttons
Use a small bowl or similar to wash and contain all the parts so you don't lose bits down the drain. Use old toothbrush to clean all button holes and buttons. Warm water with dishwash liquid does the job. Take particular care with those small buttons and clean them properly. If you can leave the bits to soak overnight they come clean easy. Ultrasonic cleaner would be goo...
step 7Rinse, drain and dry the parts
Rinse with warm water. Use a drainer to contain all the parts without losing small bits down the drain. As extra security use sink plug. Dry with a paper towel. Wipe the buttons dry individually as they may still have some dirt which makes them sticky when in use.
step 8Repair case and re-assemble
If there is damage to the case or buttons you need to do the required repairs. Use hot glue or super glue depending on fault. Let dry overnight if you had to glue something. Re-assemble bits in reverse order and make sure you have the buttons in right place and right way around. Small nicks and dents on plastic cover can often be repaired by heating carefully with a h...
step 9Test with Digital Camera
Test every button as before. Sometimes you have to push two remote buttons simultaneously as with recording buttons . Once you have completed test with your camera you can use the remote.
'Thats it, I hope you got it going again?
Posted on Oct 12, 2010
I forgot my aiwa digital 40 lock password , & it lock rightnow what can i do ?
Hello
Just try this method to overcome the situation.
With TV turned ON simultaneously press "Volume Down" button on the front panel of the TV set and digit "7" button on the remote control to reset the pin code and customer ID. You have to reset the pin code and customer ID after this process. This must solve your Aiwa TV problem. OK.
Feb 27, 2011 | Aiwa Televison & Video
Need to reset pin on VX-FT21 aiwa tv/vcr combo how do you do this???
how do i change brightness/colour/contrast if i dont have the romote control for the aiwa VX-FT 21. video/TV combo. My screen has got really dark and I cannot find a manual pannel to change it form on the TV - me and all my friends have looked everywhere but there - if someone could email me at twistedsoraya@hotmail.com that would be great. Thank you
Jan 04, 2011 | Aiwa VX-T1470 14 in. TV/VCR Combo
I lost my original remote control for my AIWA combination TV/ VCR. VX-S135 ? I bought a universal remote control but there was no code listed for an AIWA TV. Just a VCR. I need to know the code to the TV...
what's the name/make and model of the remote?
Without me knowing the type of universal remote, there is no way I can get the right code for your TV.
I look forward to your reply.
Bye for now.
Jun 24, 2010 | Aiwa Televison & Video
Tv not responding to new remote control
Was the replacement remote identical to the original one; or, does it need to be programmed. Also, if your replaced your old remote because it was not working, it might be that the IR sensor on your TV is bad.
Nov 04, 2008 | Aiwa VX-S205 Combo
I have put my wrong pin number in my combi tv ,i have now got pretected on screen how do i reset ,i have my pin number now
i have a aiwa video combi vx-t147k i have put the wrong pin number in it now says protected and witches its self off after 20 seconds how do i get the television to work?
Aug 02, 2008 | Televison & Video
Code
PIN CODE RESET - UNPLUG SET FOR 2HOURS, VOL TO MIN. PRESS VOL- ON SET & "7" ON R/C FOR 5 SECS WHEN "PROTECTED"
Jan 05, 2008 | Aiwa VX-T1470 14 in. TV/VCR Combo
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
