Question about Kenmore 57029 Side by Side Refrigerator
Drain freezing up on freezer side - Kenmore 57029 Side by Side Refrigerator
  • Kenmore Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Oct 21, 2009 | Kenmore Refrigerators
Hollow ice cubes and refrigerator freezer drip pan is freezing
The drain at the bottom of the evaporator on the freezer rear wall is blocked up. Ice may have gotten so far up the side of the evaporator that it is blocking a return air duct which is located there. You need to completely deice the freezer and then **** out and purge the drain hole on the bottom of the evapotrator with hot water and a turkey baster.
Apr 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice forming and freezing in the freezer bottom
Need to find out if the refrigerator is going into defrost normally, about every 8 to 10 hours. If it does defrost normally, does the drain inside the freezer panel and under the evaporator coil drain without blockage? Defrosted ice, (water) should go down a drain pipe and into a pan near compressor. Let me know, Thanks, Sea Breeze
Mar 22, 2009 | Frigidaire Side By Side Refrigerator 26...
Water freezing up in the bottom of the freezer
your defrost drain is stopped up then when it defrosts in steed og going down the drain its running in the freezer floor remove the back panel in the bottom of the freezer and clear the drain hole under the evaporator
Mar 12, 2009 | Kenmore 53642 / 53644 Side by Side...
Kenmore frost free refrigerator
Hi thanks for te question .If all the coils are frosted. no its not going into the defrost cycle. and you also have a problem with a clogged drain thanks the appliance doc
Sep 18, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Ice buildup at bottom of freezer and small puddle.
Freezer has a drain in the back under the cooling coil. Melt Ice from drain area with a hair dryer, check drain and clear, under bottom in back behind a removable panel you will find the drain exit from the freezer going into the drain pan. This drain line has a loop for air seal, make sure it is cleared.
Aug 08, 2008 | Maytag MSD2732GR Side by Side Refrigerator
Hotpoint side-by-side freezer drain freezes
yes totally defrost unit and verify drain is not plugged, make sure drain is trapped. it may drain into a pan on top of compressor, where heat dissipated by compressor evaporates condensate. certain crosly model freezers made by w.c. wood co. have a problem with that.
Mar 30, 2008 | Refrigerators
Water Pooling and freezing on floor of freezer
most likely you have a frozen drain in the freezer section so that whne your refrig defrosts the water runs out into the freezer compartment instead of the drain pan underneath. the fix is to flush the drain with warm water to clear the obstruction. the drain can be reached either by removing the cover in the freezer area or by back flushing the line from beneath the refrig.
Dec 10, 2007 | GALAXY Microsystems 25.4 cu. ft....
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Kenmore 57029 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
