Question about Samsung BL103 Digital Camera
When I turn on my camera it says the memory card is locked. I can't take a picture or anything.
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Oct 12, 2010
    Brigadier General:
  • 11,967 Answers
Move the slide switch on the side of the card.
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
MEMORY CARD LOCKED
All SD cards I have ever seen can be locked with a little slide on the left side as you face the label. if the slide is up, the card is unlocked and can be used for taking pictures. If the slide is down, it is in the locked position, which prevents it from overwriting anything that is currently on the card. Before you unlock it you may want to verify that all pictures on the card (if any) have been saved because once you start using the card and overwriting its contents, the pictures are gone forever. If the card is empty, just unlock it, format it and start taking pictures.
Dec 22, 2013 | Nikon D3000 Digital Camera
My cammera is locked i dont know how and why i try to take picture it says THE CARD IS LOCKED i turn it on it says the same i pretty much cant do anything, how can i unlock it or fix it????
SD type cards have a little switch on the card that can write protect or "lock" it. Take the card out of the camera and check this switch. To unlock it, it should be moved towards the edge of the card which has the electrical contacts.
There is also a software protection feature on some cameras, but this is used to protect a folder or individual picture from accidental deletion, not the whole memory. You set or release this protection from the camera menus.
If it is not that, then maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. Have you tried formatting the card in the camera? This would be one way of making sure that the camera can cope with the card, and it will also erase anything on the card. "SD" cards larger than about 1GB are actually SDHC cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC (high capacity) cards. SDHC is not backwards compatible.
Jan 08, 2011 | Casio Exilim Zoom EX-Z80 Digital Camera
When i turn my camera on it says memory card is protected and i wont take any pictures, what should i do?
The memory card is most likely an SD type and the lock swich was activated I'm including a diagram to show you the correct orientation of this switch, it must be in the open or unlocked position to function. When you have the memory card unlocked Please format the card so the camera can function properly with it. Formatting the card will insure correct programming between the card and the camera. Format the card after downloading pictures to the camera. it both cleans and restores programing so the card and camera are compatible once again.
Lock is down open is up towards the top and closest to the gold contacts
Jan 06, 2011 | Cameras
I have a canon powershot sx110is and when i turn it on it will not take any pictures but instead gives the message "memory card error." When I put it to the display mode it says the same message plus...
First see if the camera will work without the memory card installed. Then format the internal memory using the camera's setting as described in the manual.
Then turn OFF the camera and insert the sd card. Turn on and reformat the card too.
Make sure you have NEW batteries or sometimes things go flakey.
Dec 22, 2009 | Canon Powershot SX110 IS Digital Camera...
Camera says card locked
1) Try to unlock it by the lock/unlock switch on the side of the memory card.
2) If step 1 does not work replace memory card with new card.
3) If step 1 & 2 do not work the problem is internal (inside the camera). Go to www.ecasiorepair.com to get a quote for repair. Cost will be anywhere from $39-115 to fix it (if not under warranty). You could even ask if this is a defective camera (lemon) they might even fix it for free? I've seen this issue with the Casio a lot.
Dec 17, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Memory Card Locked.... how do I un-lock it?
Your memory card has a small white "switch" on the side. Move the switch and your card will unlock. It is a saftey so you don't erase anything accidentaly.
Jun 27, 2008 | Canon PowerShot A560 Digital Camera
Memory card locked!??
What you need to do is take out the card, and on the side of it there should be a little gray thing which can slide up and down. It needs to be slid all the way up. I hope this helps!!
Dec 26, 2007 | Pentax Optio W10 Digital Camera
The card locked usually means 'protected' Check out the manual for image protection - on/off. Or put card back into computer and delete[NOT FORMAT] from there. A more comprehensive manual is usually found the the CD that came with the camera
Jul 05, 2007 | Pentax Optio E10 Digital Camera
No pictures when SD disk is out of camera
Before you do anything else find a friend who's camera takes the same memory card and try it in their camera. If it doesn't work there try cleaning the contacts gently with a pencil eraser (make sure you remove any rubber pieces left behind) There is a locking mechanism on the side of the SD card. Make sure this isn't locked. If everything still fails it looks like you could have a faulty SD card. Borrow one to try to see if the fault in the camera disappears. This camera has 32 MB of internal memory. Are you sure your pictures aren't being stored there. Read your manual and you can find out how to transfer them to the SD card once you've proved the card is working. Also check your SD card in a card reader and if there's still any problems pop it back into the camera and format it. BMW
May 30, 2006 | Kodak EasyShare DX7440 Digital Camera
Samsung BL103 Digital Camera Logo
112 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
