Question about Canon imageRUNNER 2270 Copier
Describe your canon ir 2270 lan connected how can i make it print
  • clarketsp871 Dec 07, 2010
    E000110-000 ERROR CODE DESCRYBE PROBLEM PLEEEZZZZ ........
    THANK'S IN ATVANCE
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
  • 421 Answers
SOURCE: canon ir 2016 cannot/wont connect to computer via usb
You will need either the Canon PCL printer kit J1 or J2 if you want it to print (unless it's already fitted). If the copier is an IR2016J then it cannot be upgraded to a printer.
Posted on Nov 14, 2008
  • 135 Answers
SOURCE: need cd and user manual for canon Ir 2270 copier/printer
the cd is not needed goto canon and download driver for printing. as for manuals if you dont have them only an authorized tech can get the actual manuals do to canon putting them on the tech site. but you can find websites that will charge you and you can get a manual
Posted on Apr 19, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
canontech
  • 1219 Answers
SOURCE: We have a Canon iR
here is some copy/paste from the book:
Disconnection of the wire used for detecting the
connection of the toner level sensor is found.
When the disconnection of the wire used for
detecting the connection of the toner level sensor
has been detected for 7.5 min without
interruption (12.5 min in the manual /envelop
cassette feeding).
has been detected for 12.5 min without
interruption.
-iR4570/3570/3530
cassette feeding).
-iR2870/2270/2230
has been detec
As solution:
Correct the cable. Replace the sensor
My solution:
Try few times to open toner door and close it, reinstall the toner, or in service mode ( *28*) go to FUNCTION-INSTALL-TONER and let it do it work for about 600sec.
Hope that helps!
Posted on Dec 28, 2010
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
Canon ir 2270
Go To Below official Canon Printer Page For Your problem, http://www.canon.co.uk/For_Work/business-products/production-printing/cut-sheet-printers/Black-and-white/
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Canon Printer Support
Apr 15, 2014 | Canon Office Equipment & Supplies
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
Need cd and user manual for canon Ir 2270 copier/printer
Apr 03, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 2270 Copier Logo
old marine
old marine
