Question about Kenmore 63942 Dryer
Dryer run when start sw is pushed in but stop when sw is released. it is an elect dryer k/m 63942101 mt.
  • 15,935 Answers
It appears your infinite start button has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa
Posted on Oct 12, 2010
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Have a kenmore elite quiet pak ll gas dryer start buton doesn't start. when release the button dryer stops
if the dryer runs when you push the botton in and stops when you stop pushing on the button you have a bad even heat board or a bad motor relay.these parts are located inside the top console,if you send me the model number i can look up your dryer and tell you the part you need to change out
Jul 02, 2010 | Kenmore Dryers
The start switch will not stick to keep the dryer on. Is this problem in the starter switch or in the main control panel?
this is a motor sw problem . it may be full or lint / when the motor stops the sw / will reset to the start. if it does not when you push start sw it willstart and when you release it the motor stops . if you hold it too long you will smoke the motor . so delint inside dryrer. blow out motor . / this will also prevent lint fires . .. if this does't correct problem motor will have to be replaced. ,, mm
Dec 23, 2009 | Dryers
Dryer stops when I release push to start button
Timer may need to be replaced. You can test it with an ohmmeter or test light.
You can do the same with the push button. If you have more problems, then the main control could be faulty
Sep 10, 2009 | Whirlpool GEW9878LW Electric Dryer
Model 63942101 Dryer Starts\Stops after Start buttton released.
Sounds like a bad door switch. Thats about all it can be. I see this from time to time but not often.
Please rate solution.
Aug 26, 2009 | Kenmore 63942 Dryer
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
May 28, 2009 | Asko T701 Electric Dryer
Kenmore dryer won't heat and must hold button down
Switch on fan motor not working sw must prove that fan is running! bad motor sw or loose wireing motor sw will by pass start button is released if working!
Jan 04, 2009 | Kenmore Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Kenmore 63942 Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
