Question about Hobart AM15-5 Dishwasher
Booster heater contactor not coming on - Hobart AM15-5 Dishwasher
  • 37 Answers
There are several causes for this.is it new it might not be programmed right.(ie) not set to hot machine.
Posted on Apr 22, 2011
Wire a 220v heater to a transformer, contactor, and thermostat
one side of transformer secondary to one side of contactor coil. the other side of transformer secondary thru t stat to other side of contactor coil. line voltage 220v to l1, l2 of contactor . other side of contactor to load (220v heater. ) Make sure heater has some sort of overload /overheat safety either breaking line voltage or control voltage 24v.
Nov 27, 2013 | Heating & Cooling
Jet tec f18 water goes to 120f redy light does not come on will not wash got hot water to 120f open door have steem but no wash frank
Verify the contactor for working condition. maybe burned wires or bad contactor. if it is good then the rinse thermostat or, less likely, the booster element.
Oct 07, 2013 | Jet Tech Systems 24 in. F18DP...
Hobart lxih heating water to 212 degrees and showing so on display
i would contact main office #937-332-3000 or Service Office 1-888-446-2278 .
Aug 02, 2013 | Dishwashers
Rinse temperature too low
your right dont guess the board is bad!
Aug 08, 2012 | Hobart AM14C-155 Dishwasher
Hatco c-9 booster heater won't heat, 1 amp fuse keeps blowing
that is in the control cicut the contactor might be bad and taking out cntrl fuse.unhook contactor control voltage by unplugging from contactor tape off the two wires put new fuse in turn on power if fuse does not blow replace contactor.if it does blow you will have to isolate the next thing in the control circut maybe the light.you can buy resetable 1amp circut breakers at grainger for test purposes.sometimes on people I know I will wire in those breakers for them no more buying fuses.
Apr 11, 2011 | Hatco Corporation Compact Electric Booster...
Hobart LXIH stuck in Wash mode after running multiple loads. Shutting off breaker for several hours fixes problem until multiple loads have been run again and then it is once more stuck in Wash mode.
How long does it stay in the wash cycle? Indefinitely? Does the display continuously show "WASH"?. If it stays in the wash cycle indefinitely (i.e. continuously shows "WASH" for significantly beyond approx. 3 minutes), it's probably a control board malfunction. If it continues to wash after the "WASH" indicator goes out, it could be a shorted wash motor relay on the relay board or a fauly control board.
If the internal rinse water booster heater doesn't reach it's programmed setpoint temperature in time, the dishwasher will run an extended wash cycle to give the booster heater more time to finish heating the rinse water. If this is what's happening, the wash cycle would last approximately 3 minutes, then it would rinse regardless of whether the booster heater has finished heating or not.
The booster temperature thermistor may be bad, giving a false booster temperature reading, causing an extended wash cycle as described above. The booster heater elements or contactor may be bad, preventing the booster heater from heating and reaching proper temperature, also causing the same extended wash cycle to give the booster more time to heat.
Jan 06, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I have a hobart lxih that fill runs once and steam comes out on rinse than flashes P3
Probably a bad booster tank termperature probe (thermistor). This is threaded into the booster heater and has two small black wires entering it.
The following procedure will result in a some water coming out of the booster heater. Allow the booster heater to completely cool, and shut off the circuit breaker for the dishwasher before proceding.
Prepare a new temp. probe with teflon tape, then unscrew the old probe from the booster heater and quickly install the new probe. Assuming the heater is cooled, you can hold your finger over the hole vacated by the old probe to prevent excessive water from pouring out of the booster heater.
Oct 22, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
I was looking at a 4 ton split system,goodman indoor and outdoor fans come on but no compressor think it's the relay but didn't see 1 in the furnace control board,is the relay inside the contactor on the...
Try to put a booster cap in parallel with the compressor capacitor ,but if still the compressor won't start it has a problem and because it's hermetic it has to be replaced.
Sep 14, 2009 | Heating & Cooling
Electric space heater contactor won't stay latched
Jumpered the bimetal thermostat and everything worked smoothly. Tried to clean contacts in thermostat with no luck, so ordered a replacement. At least it was cheaper than the contactor.
Dec 07, 2008 | Fahrenheat Ceiling-Mount Industrial Heater...
Hobart AM15-5 Dishwasher Logo
115 people viewed this question
Top Hobart Dishwashers Experts
Jason
handygirl911
handygirl911
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
