Question about Kenmore Elite HE4 Electric Dryer
I have a kenmore elite dryer- MODEL 110.6506*- it works but keeps putting time on the dryer- I have cut the power off- opened the door- turned off the sound- continues to beep and put time of 20 to 30 timed minutes- I have let the time run out with nothing in the dryer- keeps putting the same 20 to 30 on timed drying. Looked in the owners manuel there is nothing covering this. Got a guess- thanks
protek480
  • 1714 Answers
SOURCE: Dryer won't dry
That is a bad gas valve, change it.
Posted on Sep 02, 2009
  • 114 Answers
SOURCE: Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Posted on Sep 09, 2009
SOURCE: kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Posted on Oct 08, 2009
SOURCE: Kenmore Elite Oasis Electric Dryer, Model #110.6708*, 6709*
Hi, my Kenmore Oasis Elite electric dryer has a poor fitting lint screen which allows for a large build up of lint in the bottom of the motor housing. This lint has also become blackened as if exposed to high heat. Some electric wires also show evidence of the plastic coating turning black and over heating. I get the feeling this unit is a fire hazzard. Model # C6704 A few days ago there was a distinct odour of electrical burning. This unit was purchased new in Dec. 08. Anyone else have this experience?
Posted on Apr 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Smartheat Quietpack 9
Unplug the unit for 40 minutes and try to reset the main controller. It may just be out of sync.
Let me know.
Thanks!
Posted on Nov 15, 2010
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
Hi I have kenmore elite dryer, model 110.85091400, it was working just fine Yesterday I opened the door to add a sock in it , I thought I pressed pause before opening, shut door and pressed start. It...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2010 | Kenmore Dryers
My dryer wont work. my kenmore elite wont turn on. the light in the dryer is working so I know there is power to the unit but the control panel wont turn on. The model number is 110 60092991
Kenmore by Sears,
DD
This is really a simple project
I believe your belt broke and Kenmore put a kill switch to protect your motor and heating element.
there are two screws when you remove your lint screen.
Remove those screws.(philips)
With a straight screwdriver, gently pry up the top of dryer.
When loose, open all the way to the back and rest on the wall,
On each inside,behind the door, at the top, is a 1/4" bolt. Use Socket to Remove both. Pull up and out on the front and put it to the side.
Remove the drum.
Now you can clean the inside with a vacumn. See the kill switch in front of motor.
The model is inside the door on the left
since you have it apart check the drum rollers for flat spots as well as freedom in movement DO NOT GREASE
Put it back together
Jul 24, 2010 | Kenmore 63942 Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My dryer model kenmore 110.85862400 has power but does not turn on...is it possible that I locked it somehow? Do you know how I can unlock if thats the case. Someone told me to check fuses or breaker as...
Faulty door button or faulty thermo cut out located on the heater housing Check for oms Door switch when pushed in and thermal switch when power is applied
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite QuietPak 9 Dryer - door opens constantly
I'm not solving the problem, but just wanted to say I have the same problem for the same dryer
Aug 04, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
cutiepie, I've seen this many times on these dryers. You need to replace the door hinge. Not really a hard job to do. Post a model number (inside door) and we'll get you a part number...Catriver..post back.
Feb 18, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
