Question about Konica Minolta Bizhub C300 All-In-One Printer
We have an error message on our Bizhub C300 color copier. It is C-5102. What is the problem?
  • 1,110 Answers
C5102 means that your main drive motor is not turning when it should. This could be as simple as a loose power connection on the motor but that would be very un-likely. Most often this code is caused by something in the machine that is turned by the main drive motor has beccome stuck or has "frozen". This causes the motor to not be able to turn as it should. If turning the machine off then back on does not reset the code and restore the machine to operating condition then you will need a service technician to come out and determine was part has locked up.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 12, 2010
Receiver exchange error message
replace the trim waster with a new one
Mar 23, 2014 | Konica Minolta Bizhub C 6501 Color...
C-5102 error in C353
Transport motor dealing with the duplexer which helps with making double side copies, your right side of the machine the cover has to opening outer open section is causing the problem check it and have a tech come out and check it.
Feb 08, 2014 | Konica Minolta Bizhub C353 Copier
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
Bizhub 164 error code c-5102
Code
C5102
Description
Main motor malfunction
- The main motor (M1) lock signal remains HIGH for a continuous 1-sec. a period at any time 1 sec. after the main motor has started turning.
Remedy
1 Check the connector between M1-PRCB CN6 for proper connection and correct as necessary.
2 Check M1 for correct drive coupling and correct as necessary.
3 M1 operation check.
4 Change PRCB.
5 Change DCPU.
Oct 03, 2013 | Konica Minolta bizhub C250 All-In-One...
I have a Konica Minolta Bizhub c252 what is code c-5102
C-5102/5103 - Main motor failure.
Check the motor connector,the drive coupling or the mechanical control board and DC power supply unit.90% mechanical rpoblem.
Feb 26, 2013 | Konica Minolta bizhub Office Equipment &...
Error code c5102 on bizhub c353
I tried all the above but still it shows code C-5102.
Please advise.
Apr 17, 2012 | Konica Minolta Office Equipment & Supplies
How to configure bizhub c300
can you check the protocal settings in printer properties
Dec 28, 2011 | Konica Minolta Bizhub C300 All-In-One...
Bizhub C300 error C8103
To improve paper-feeding in the paper take-up section of the document feeder some adjustments have been newly made. Please ask a technician for this updates, but the error code suggest binding in the lift motor (may need to be replaced) or the lift plate is not producing enough pressure.
Jan 15, 2011 | Konica Minolta Bizhub C300 All-In-One...
Imaging units for Bizhub C300
There is no setting you can extend the life, however, in the service mode ( utility->meter count-> stop, 0, 0, stop, 0, 1) then press stop, 0, c. There should be a setting in there that you can disable the "image unit life end stop" setting. You will get a message every 5 minutes telling you to change the unit, but your machine won't stop working. Otherwise you can just change the chip in the image unit.
Jul 26, 2010 | Konica Minolta bizhub C450P Laser Printer
Konica Minolta Bizhub C300 All-In-One Printer Logo
777 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
