Question about Dell Vostro 1320 Notebook
Dell vostro 1320. battery ran low so i plugged it in. It says Plugged in but not charging. The system will run when plugged in. Is it the battery or the plug ?
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 12, 2010
My dell vostro 1320 , is not starting the screen is black and the padlocks on it are blinking with a number 9
Posted on Mar 21, 2011
Dell laptop wont charge battery.
The Laptop charger or the charging point itself is bad or damaged. You'll need to try different charger to take your laptop to any nearest computer repair shop to have charging point repaired or replaced.
Oct 28, 2014 | Computers & Internet
In dell vostro 1510 laptop, when adapter is connected to laptop it showing "plugged in, not charging"
is battery already fully charged? Most of laptops disharge the battery while connected with AC adapter, they do not keep the charge at 100%.
Oct 10, 2013 | Dell Vostro 1510 Laptop
No light indicator charging battery adapter
If the computer starts with the power charger plugged in, then replace the battery.
good luck
Sep 20, 2013 | Dell Vostro 1014 Notebook
Battery low while already plugged in
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Dell Vostro 1000 Laptop
Dell Vostro 3750 plugged in not charging
My work mate's laptop would not charge the battery either, when I put the battery in an identical laptop it would not charge there either. When I placed my battery into his laptop it charged it just fine. The problem is with his original battery pack.
Mar 21, 2012 | Dell Vostro 3750 PC Notebook
Lap top will not charge battery
Sounds like the charging circuit on your motherboard is defective. Also check the AC adaptror by switching it with other Vostro.
Jan 30, 2012 | Dell Vostro 1014 Laptop Computer (Intel...
After about one year of having my Dell Vostro 1320, a message popped up saying that my battery is fully charged, but that I should consider replacing it? How can this be after only one year? Is battery...
Just another example of our throwaway society. I am currently dealing with two cell phones indicating battery failure at an early age and a laptop computer with an "unavailable" replacement battery.
Oct 07, 2017 | Dell Vostro 1320 Notebook
My dell vostro a860, when i plugged adapter its showing me plugged in not charging and continuously battery is not charging.
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jan 26, 2011 | Dell Vostro A860 Notebook
Replaced Vostro 1400 Battery is not charging
You might have a defective ac adapter or power related problem on the system board. Go to radio shack and see if they have a tester adapter (most have universal laptop power adapters and you can try in the store to see if this works). If same issue, most like a defective battery or defective system board.
Feb 15, 2010 | Dell Vostro 1400 Notebook
Dell vostro 1000 laptop
Replace the battery. Their batteries only last 2-3 years max.
Cheers,
gurutim
Mar 20, 2009 | Dell Vostro 1000 Notebook
Dell Vostro 1320 Notebook Logo
1,359 people viewed this question
Alun Cox
