Question about Whirlpool Refrigerators
Hot mtal beam between doors
7 year old side by side Kenmore/Wirlpool refrigerator, getting very hot on the metal beam between the two doors. Some area on the left side is also getting hot.
  • xz1234 Jun 01, 2008
    Thanks. Just checked and the fan is not moving. Is it a fan problem or something else? Is it easy to order and replace the fan? Thanks again.
  • xz1234 Jun 10, 2008
    replaced the fan, but it is not running, not at any time. Please help.
    Scholar:
  • 110 Answers
You have a condenser fan mtr that has failed
Posted on Jun 01, 2008
  • MARLON KELLER Jun 01, 2008
    JUST ORDER THE FAN. YOU CAN GET IT AT WWW.SEARSPARTS.COM
  • MARLON KELLER Jun 11, 2008
    do you have the t-stat turned on and if so is any of the fans attemting to run if not your machine could be in defrost. recheck all your wire connections and make sure you have at least 110 volts coming to the fan
The beam in middle of refridgerator where both doors rest against while closed is too hot to touch
Is the cooling fan for the compressor working? There is a coil of the condenser line that runs around the freezer side. This will get hot but the cold freezer side keeps it form not getting too hot. It could get very warm if the freezer is not cold yet.
Sep 10, 2014 | Kenmore Refrigerators
When you open the freezer door the metal in hot to the touch
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Aug 29, 2011 | Kenmore Top Freezer Refrigerator
Kenmore elite side by side w/ middle divider super hot
absolutely not
that middle peice should be hot to the touch
this is the mullion heater or yoda loop in the old days
this is what controls moisture from entering the unit
when you open the dooor
mine has been running for 7 years no worries
Oct 27, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Front metal , top heating element very hot
This should be OK. There are heat strips placed behind the door frame to prevent sweating around the door frame due to the metal being cold normally without the strips. Thanks, Sea Breeze
Jul 21, 2009 | Refrigerators
Refrig is hot to touch
Hi, Have you checked to see if there is a frost build up in the freezer? How are the temperatures in the fresh food side or the freezer side? Check and make sure the evaporator motor is running in the freezer. Please let me know if you find any of these issues. When that area is hot, usually there is more going on and the temps are not right. Let me know so I can assist you further.
Thanks
Vic
May 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Outside of refrigerator is hot - almost burning hot
The frame between the doors has a refrigerant line running through it to prevent moisture build up between doors (should be room temp. or slightly warm, not hot).
If that area between the doors is hot to the touch, you have two things to check: 1 - are the condenser coils under unit or in the back clean? 2 - is the condenser fan running in the back that is near the compressor running?
Aug 24, 2008 | KitchenAid KSCS25IN Side by Side...
Warm to Hot molding that seals the doors
The heat in door frame is normal but undetectable when ref at normal temp. Definitely cooling problem. Google ref not cold enough to get help to solve problem. Never use any oil for it will not help also health problem if not approved to be used around food. Fan motor must be replaced for it will just keep stopping.
Mar 31, 2017 | Kenmore 52642 / 52644 / 52649 Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Refrigerators Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
