Question about Vestax Handy Trax Turntable
My volume fader makes an awful crackling noise when it moves, i've tried cleaning it, but the black grime is endless. Any advice?
Distortion in speakers when i turn the tuner knob it hits some hard spots they quits
Turn the stereo off, then quickly turn the volume knob back and forth for about a minute to get rid of most of the grime that is causing the static. Then turn it back on. if that doesn't work...
You can try cleaning out the potentiometer.
If that still doesn't work. replace the potentiometer
Feb 25, 2016 | Audio Players & Recorders
Djm 700 crackling through all channels
There is a contact cleaner spray available at most stereo, tech stores, that may assist you with your dilemma. The pots or potentiometers are dusty. You could even just use air also to clean them out better. Just some advice hope it helps..
Nov 27, 2013 | Pioneer Audio Players & Recorders
Hotpoint Aquarius dishwasher making awful rumble/crackle noise
Have you cleaned the traps and run some vinegar through? They build up dirt from kitchen debris over time which causes the pump and spray rails to pick up sludge. You need to clean them at least every 6 months. Check farther on line for cleaning solutions to clean and maintain dishwashers. I have been hearing clr can be used but can't confirm this.
Oct 23, 2017 | Dishwashers
Bose speaker service
If the speakers are making a crackling noise at high volume yes, you need to take them in for service. The main problem that I have found to cause this issue is faulty instillation from the factory or using the system at a high volume with music. If it were me, I would send them in to Bose. They are a great company and will work with you to fix the issue.
Aug 17, 2012 | Bose 301 Series V Direct/Reflecting...
My Aiwa powererd sub-woofer TS-W50U) has crackling sound.
Crackling is an unusual noise but typically indicates a bad capacitor in the amplifier board. This can be a rather costly repair but first we will go through basic trouble shooting steps.
Reduce the volume on the sub and see if the noise remains and changes with the volume.
Unplug the sub and disconnect interconnect cables. With both hands push softly on the speaker cone to move it in, let it back out and do this a few times. If you hear a scraping noise and some resistance your driver is misaligned and you need to recone or replace the driver.
Check all your interconnect cables, there may be a bad internal connection (usually causes pops and cut-outs).
Let me know how things workout. If it makes the crackling noise at all volumes and the driver seems fine then I would seek a professional to repair it, or replace.
Cheers,
Kevin
Feb 09, 2010 | Aiwa Audio Players & Recorders
Crossfader Selectors scratchy
The sliders on MOST of the mixer devices are pretty weak. They are subject to dirt or liquid getting into the slot and spoiling them. Fix is to replace them. You usually can find replacements at Digikey or Mouser that are suitable. The parameters are the resistance, the packaing and the length of throw AND importantly the "taper" of the resistance element.
Sep 08, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Speakers make crackle noise.
tried to reinstall/update your audio drivers and tixed your sound equlizer.
Apr 06, 2009 | HP Pavilion dv9000z Notebook
Turntable Crackling
sounds to me like your fader has popped! lube contact spray will not solve the problem, it will only clear it up for a few passes if any! PCV faders have covers inside which stop any lube getting right on the contacts! but in my experience as a scratch dj for 11 years is that contact spray only make the problem worse over time! best shot from here is to replace the fader, or get a mixer with optical/contactless fader i suggest a mixer with the 'eternal' fader i.e. ecler 360/80hak. hope this helps
Feb 03, 2009 | Technics SL-1210 Turntable
Stereo receiver crackling noise
open it up and spray it with contact spray. move left and right and then spray again. this will normally do the trick. the crackling noise comes from standing in the same position for to long.
Aug 13, 2017 | Audio Players & Recorders
Vestax Handy Trax Turntable Logo
47 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
