Speakers wont turn down
The speakers wont turn down and every time i plug them in the the computer they make a loud buzing noise
  • Anonymous Jun 06, 2008
    just get a ticking sound.no speaking
    Problem Solver:
  • 5 Answers
Its the audio quality in windows settings. go to the cpanel and change the sound volume in windows sound settings
then change volume. it should work otherwise. there old speakers. try buying a new bose speaker or something.
Posted on Jun 13, 2008
Why do my desktop computer speakers have a humming noise all of a sudden? They were turned off for a couple of days .
Check the speaker cables for connectivity. Be sure to securely plug in the stereo jack/s at the back of your pc
Jul 21, 2014 | Logitech Audio Players & Recorders
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
Buzing noise from power unit
What kind of system is it?
What "power thing" inside what?
It's a good chance its a ground loop issue.  Make sure the power cords aren't wrapped around each other or touching the speakers or running parallel with the speaker wires for more than a couple inches (interference transmitted into the speaker lines audible through speakers).
Aug 04, 2009 | Sony DAV-SA30 System
Speakers making loud pitchy noise
If they are computer speakers try this: (remember i am doing this from a windows vista) on the bottom right hand of the screen there should be a volume key right click on it and click on playback devices then right click on your speakers and click properties and go to levels and turn down the volume from there and see does that work... hope this helps.
May 26, 2009 | Harman Kardon HK595 Computer Speakers
Scratchy loud noise when volume dial is turned
It means that the volume pot is dirty.You need to find a way to get some WD-40 into the pot.This usualy requires that you take the access to the inside off and spray right inside the pot.Once you do this move the volume dial from min to max a few times and it should fix it.
Jan 05, 2009 | Altec Lansing VS2221 Computer Speakers
Constant loud muffled noise coming from the sub and speakers.
Try playing with the connection, sounds to me maybe the jack is going bad or has a shorted connection. Plug it in and out slowly to see if that's the issue.
Sep 25, 2008 | Logitech Z-5300 Computer Speakers
Loud whining noise
yes,,this is due to electromagnetic interference...
try to keep the accessory speaker as far as possible fro the powerspeaker..this would serve better
Jul 04, 2008 | Bose MediaMate Computer Speakers
Popping & hardly any volume
i had the first problem and you can probably fix it by turning the volume knob all the way up and down about 20 times. it worked for me. supposedly the potentiometers in the z-5300 get dirty or worn out, somehow this might fix it. for the second problem maybe try plugging it into the laptop and unplugging it again seeing if it goes back to normal?maybe its a problem with the amp?
May 07, 2008 | Logitech Z-5300 Computer Speakers
Loud buzzing noise
Bad connections or faulty wires check the wires and the connection of the wires, usually the buzz is a bad earth
Nov 16, 2007 | Acoustic A-5640 Computer Speakers
361 people viewed this question
 Grubhead
Grubhead
