Question about Sony Televison & Video
I have a Sony tv KE-32TS2E The problem with this tv is solarisation I have established that the problem is in the power supply board ( by ellimination) How can I find out which component in the power supply board is causing this problem.
  • Sony Master
  • 11,800 Answers
The only way to find out is to test it: if you don't have a great experience in electronics the only way you can do it is to take it out of the tv and check every single component. Start with the transistors, follow with the rectifiers, then check the stabilizers and finally the transformers.
Posted on Oct 21, 2010
Hello, i have a sony ke-42xbr900 and the box flashes 9 times (red light) and the tv flashes 6 times (red light), i changed the G board (power supply) from shop jimmy and still have the exact same prob
The R1 or R2 probably the problem. visually inspect each PCB for blown or burnt parts. R1 pt# A1401606B R2 Pt# A1401891B, but these don't appear to available anymore. I have checked with tristate, encompass, shopjimmy & thetvguys
Dec 31, 2014 | Sony Televison & Video
Why Sony WEGA 42 in. Plasma will not power up?
Fault with the main power supply regulator board.
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
Aug 06, 2014 | Sony WEGA KE-42XS910 42 in. HDTV-Ready...
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
I would like to replace the power board where can i find one to replace the old one and can i send the old one in for a discount. Thank You,Kevin
U can try searches and buy a reburbish tv power supply board at Ebay.com for ur tv the replacement.Tries ur area where u live,find tvs shops get priced quotes and get repair by them.
May 16, 2011 | Sony WEGA KE-50XS910 50 in. HDTV-Ready...
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony WEGA KE-42M1 sound but no picture.
i have the same problem! did you ever solve the issuE??
Oct 16, 2009 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
My sony ke-mx42a1 shuts down and the stanby
Normally, this happens when the TV detects a bad circuit board and goes into " Protection Mode ". The blinking red light should be a error trouble code. Most likely the TV has a power supply related problem. It's possible that it maybe a bad capacitor or transformer on the power supply board. But, I can't say it's 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptoms.
You have a few choices:
1. You can try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Jul 14, 2009 | Sony KE-MX42A1 Television
FLAT PANEL TV
Hello, there is a possibility that the power supply is broken. Replacement of the complete power supply board Part number: 146872116 will cure the problem. Best regards, Arpi
Mar 22, 2007 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
61 Inch Sony Plasma KE-MR61 needs to be repaired
Ke series makes that an early plasma TV
that old will probably be throw away or requires the replacement of the whole printed circuit of the TV
or power source
if chinese built that circuity may no longer be available
any local mobile TV repairer can check that TV out for you
check out the internet for sony corporation south africa
for parts availability
Mar 30, 2017 | Sony WEGA KDE-61XBR950 61 in. Plasma HDTV
Televison & Video Logo
117 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
