Question about Ricoh Aficio 150 Copier
How to fix polygon mirror motor for aficio 150
  • 1,110 Answers
Generally these motors can not be "fixed" once they fail. You can buy them brand new online for well under $100 which also makes it hard to justify repairing. The part number you need is G0291961
Just do a search for it and replace it with a new unit. You will have a much higher chance of properly repairing the machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Posted on Oct 12, 2010
Mp161 prints half page
This problem is usualy related to the laser unit/Polygon mirror motor. Ask your local technician to replace the polygon mirror motor, this part is normally cheap.
Dec 23, 2013 | Ricoh Aficio MP 161 Black and White Copier
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Ricoh2035 problem code sc 329
SC320: Polygon motor error
- Possible causes -
· Polygon mirror motor defective
· Poor connection between the polygon mirror motor driver and the BICU board
· BICU board defective
Dec 28, 2010 | Ricoh Aficio 450 Copier
Aparece el error SC 320 que puedo hacer??
320
Symptom
Polygon motor error
The polygon motor does not reach its operating speed within 10 seconds after the polygon motor on signal, or the lock signal is not detected for more than 200 ms continuously during operation.
Possible Cause
• Polygon mirror motor defective
• Poor connection between the polygon mirror motor driver and the SBCU board
• SBCU board defective
Nov 13, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have code SC320 of my copier NASHUA D425
-Definition- [B]
more than 40 ms continuously during operation.
- Possible causes -
· Polygon motor defective
· Poor connection of the interface harness which connects the polygon
motor driver and the IOCSS board
· IOCSS board defective
u need new polygon mirror
Nov 07, 2010 | Ricoh Aficio 250 Copier
When you put the machine on this is the error you see SC320
Polygonal mirror motor error.
You will have to replace the Polygonal mirror motor.
Feb 20, 2010 | Ricoh Aficio 1018D Copier
I have problem with Ricoh Aficio 1113, error code sc320
I am assuming you really meant an Aficio 1013 - SC320 indicates a polygonal mirror motor failure. This motor drives the mirror that distributes the laser to the drum. Could be a defective motor, poor connection between the motor and the BICU - one of the motherboards, damaged cable or defective BICU.
This will require a service call. Probably looking at an hour to diagnose the exact problem and an hour or two to repair plus parts. Could be as simple as a loose connector --- doubtful, but you never know.
Dec 24, 2009 | Ricoh Aficio 150 Copier
TROUBLESHOOTING ERROR CODE SC320
SC-320 Polygon mirror motor error:
Symptom: Did not detect lock signal from
polygon mirror motor within 10
seconds after motor ON signal;
or, lost lock signal for
continuous 1.5 seconds after
signal was detected.
Cause:
1.Polygon mirror motor (or harness)
defective
2.FCU defective
P.S. Remove LSU. Turn out poligon mirror.
Clean & lubricate.
Jun 19, 2009 | Ricoh Aficio 150 Copier
Error SC320 appear on screen..
Polygonal mirror motor error change...
The polygon mirror motor does not
reach operating speed within 10
seconds after the motor ON signal is
sent, or does not turn on within one of
the 200 ms check intervals during
operation.
• Poor connection between the polygonal mirror motor driver and the BiCU board
• Damaged cable between BiCU/IOB and polygonal mirror motor driver
• BiCU board defective
Mar 24, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio error code sc 320 what is this and how can I fix it.
Polygon mirror motor error/lock. Unplug the copier. Wait 20 seconds. Plug it back in. See if that makes it go away.
Otherwise you should get a hold of a service technician but getting parts for a 250 is very tough. It could be the polygon motor, the power supply, a cable, or a board. It will take some time to troubleshoot.
Oct 30, 2008 | Ricoh Aficio 250 Copier
175 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
