Question about Maytag MSD2756G Side by Side Refrigerator
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
  • 1 more comment
  • mtrangaris Oct 13, 2010
    I read your solution. The compressor relay clicks but the compressor does not start. All fans are working. I can see no damaged parts? I do not know where the relay is?
    So, given the presenting problem, is the compreso]sor relay my likely problem. Everything else seems to work but the compressor that is warm does not start. The relay clicks. Could it be something else? If so what?
    So it would seem that I could take a chance on the relay and otherwise it is probably the compressor. The compressor is hot but not too hot to touch.
    President:
  • 1,932 Answers
Check whether the compressor is running.Check the relay of compressor also
Thank You
Posted on Oct 13, 2010
  • 4,066 Answers
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Posted on Oct 12, 2010
jumptrout51
  • 3361 Answers
SOURCE: the refrigerator section is not cold
Replace the freezer fan motor.
Posted on Feb 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: fan runs freezer and fridge don't cool
Please check the model number again, I can't locate that number. The number should be like for example 194.258978 Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
  • I think your refrigerator has a defrost timer and this may be the problem, Let me know what you find, Thanks, Sea Breeze
Posted on Mar 29, 2009
  • 40 Answers
SOURCE: Top refrigerator not ccoling and bottom freezer
check the condenser temperature when the compressor is running by hand it must be warm or hot if it is not then that means no refrigerant left in the system.This can be a possible cause.
Posted on Sep 27, 2009
Testimonial: "Thanks so much for bringing it home. I can stop trying to fix it myself now and call the Tech with specifics."
  • 1218 Answers
SOURCE: Refrigerator fan running not cooling
Good day,
That is the compressor not running. Could be a bad compressor, or one of it's starting components.
You can remove the start components from the compressor, by removing the cover, and pulling them off the compressor pins.
Any decent sized appliance parts house will test the components, usually made up of the overload protector, start relay, and on some models a start/run capacitor.
If any parts check bad, replace them, if they all check O.K. then you will need the services of a trained service tech.
Posted on Feb 20, 2010
heatman101
  • 43501 Answers
SOURCE: Refrigerator not cooling
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Posted on Apr 11, 2010
Ref has quit running/cooling. Lights inside are on, the lights on the temp controlls are off. Any isea?
I ran into this problem last year on the same or similar model.
if there is no cooling or fans or compressor running ,but lights are on in both compartments,and no control numbers are on the electronic control mounted to the left of the compressor is the cause of the
problem. It is expensive but rebuilts are available on Ebay .Ive
used national rebuilder parts many times,with excelent results.
Apr 30, 2014 | KitchenAid Superba Architect KSCS25INSS...
I have a Dometic rm3801 it was working fine on 120v and abruptly quit cooling all lights come on compressor and cooling fan don't run. I aam unable to try it on lpg. Fridge is level and cooling fins are...
If the rear cooling coils are warm and the refrigerator is level and there is still no cooling, then you more then likely will need to replace your cooling unit. It takes a couple of hours to do but you dont need any specialized tools. Check out ArctiCold Refrigeration We keep it cold Your unit can be found on ebay at under half the price of a new fridge. Link Below 11d6ec30-092e-426d-853a-24315c5d73c1.jpg Dometic RM3801 Brand New Manufactured Cooling Units LIFETIME WARRANTY...
Sep 25, 2013 | Dometic Refrigerators
I have cleaned the coils this morning, but the refrigerator section does not appear to cool. The freezer seems fine. This is model eti18PKXGWI ser no. 042 9086 eemingly c. 10 years old.
Your freezer fan has probably quit. On most refrigerators the freezer is the only compartment actually cooled by the compressor and coils. The refrigerator compartment is feed cold air from the freezer compartment by way of a small fan. If you have you refrigerator turned all the way up and the door open you should here the fan running and be able to feel air moving somewere in the refrigerator compartment.
Sep 05, 2010 | Whirlpool Refrigerators
The Unit does not cool. The fan, lights, etc run
check if the compressor working if it working and you get frost in your freezer back panel then your problem is in your freezer area but if your compressor not working then and the fan next to it working then the starter unit for the compressor is bad....let me know if you need more help
911service today . com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
Kenmore SxS 596.52673200 stopped cooling
You have a refrigerant leak. Your coil in the freezer should be frosted. You're looking at 600 dollars minumum for repair.
Sep 12, 2009 | Frigidaire FRS23H7CS Side by Side...
Evap fan stops running/low cooling, Unplug Frig Evap fan runs
Is there anything obstructing the fan area, ice build up ? It is normal for your freezer to get warm if evap fan is not working, it is essential for it to work :) A defrost cycle should kick on a timer or as needed (adaptive) and there should not be excessive frost buildup that it blocks your evap fan. I would have suggested you unplug your refrigerator for about 10 minutes and see if that resets your control board - if not, then you will need service - either replacing motor assembly or a faulty control board.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
May 19, 2008 | LG LRTBC1825T Top Freezer Refrigerator
Refrigerator stopped cooling
The most common problems for refers not cooling is a condenser fan motor (the one that cools the compressor) is out. This can be caused by either a mouse has tried to jump trough the fan and it came on or a loss of grease or oil. There is no way to oil them so they have to be replaced. That is the problem especially if you unplugged the refer and it worked for a while then quit. If the fan doesn't cool the compressor it will overheat and shut down coming on intermittently then shutting off again. As for the refer that still doesn't cool when everything else does you may have an burnt overload also. Check the compressor area for burnt or stalled components ex. fan motor, relay, overload. If your compressor is out plan on spending from $300.00 to $500.00. But check the suggested components first. And beware there are appliance shops out there that will find one of these problems and give you an estimate for a compressor. Find someone reputable.
Jun 18, 2007 | KitchenAid Superba Architect KSCS25INSS...
Maytag MSD2756G Side by Side Refrigerator Logo
172 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
