Question about RCA D52W19 52" Rear Projection Television
SPARKING in the REAR!!!!!!!
My RCA 52 in. TV when it is plugged in will start sparking in the back at the bottom of the tv. It smells and sounds like a fire cracker. when we pulled the back of the tv back it is a silver peice in the low left hand corner a little smaler than my fist. Please any information i can get i would greatly appreciate! what is it and how do i fix it???
thanks.
  • 927 Answers
It sounds like it may be the IHVT, flyback or high voltage transformer. Go to your local RCA service center and purchase it, but if you are not skilled in soldering , I would recommend that you seek a factory authorized service center to properly repair your unit, not only for reliability but first your safety.
Posted on Jun 01, 2008
Sparking at back by plug ins
sparking normal...... but ensure the lamp is firmly in place in its chamber the sparking will go off
Jul 07, 2013 | RCA D52W19 52" Rear Projection Television
Rca 52'' rear projection tv
Thats usually the gray box capacitor CL031 which is about 2 inches in front of the flyback or the flyback itself. Thats the only two items that will cause that on that chassis.
Dec 23, 2009 | Televison & Video
My tv will not come on and sparks when i plug it in
If it sparks when plugged in that means the main fuse in the tv is not blown. If there was sorting wrong with the tv and you saw sparks the fuse should blow. If the fuse blew you will not see sparks anymore and the set will not come on. But if the fuse did not blow one of the following can be the cause.
1. A short in the line cord, check you plug and wire to make sure there are no breaks in the wire.
2. Sparking can be from a bad outlet, a plug that is not making good connection can cause sparking, try plugging in to another outlet if it still sparks check the prongs and make sure they are not blackened.
Oct 05, 2009 | RCA P52937 52" Rear Projection Television
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv powers off and on about 3 times then a little black box in back starts sparking. Its a 52 inch RCA. Thanks.
Be careful , can start a fire, keep unplugged,. you may have to get a repair man to look at it. Sounds like a short to me.
Aug 16, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca p52770eb wont come on sparks in the back about 2 inches from the power cord inside the tv
On some of the RCA televisions, the Hi Volt transformer will go bad and make a sizzling or popping sound. Most often, it will smell burnt when this happens.
Jul 17, 2009 | RCA P52926 52" Rear Projection Television
Sparks and burning plastic
Leave the back off and try to power the set on...be ready to pull the plug. Whatever is sparking/smoking is your bad part. On this TV I would suspect the flyback transformer or grey rectangular polyester capacitor mounted in front of a heatsink on the left.
Jul 06, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
RCA HD52W58 Picture not working / Sparking in back.
maybe there is a lizard inside, open the back cover then remove the PCB. re solder the damaged area and clean it with an electronic spray cleaner. check for cold solder component leads and re solder it.
Jun 11, 2009 | RCA HD52W58 52" TV
Louding sparking in the back panel.
more likely its the flyback arcing which is a common problem with the ITC222 chassis which is what your model is. You can get replacement 259296 flybacks at the following link with free detailed instructions with pictures so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Nov 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
70 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
