Question about Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700
Key in code, lite turns green, but does not unlock lock
  • tolsond Oct 12, 2010
    yes, with the key it is fine
    code is entered lite turns green, but door does not open
  • 3,740 Answers
Hi and welcome to FxYa, I am Kelly
I would erase all programing and start a new for this reason:
Restore Factory Default (original settings that were set at the factory will be loaded).
1. Remove the battery pack, and with the batteries disconnected, press any numeric key for 10 seconds and release.
2. Connect the batteries and--within 3 seconds--press and hold ;. After hearing 6 additional beeps, release ;.
The DL2700 is now clear of all programmed data, and the lock is now ready to accept new programming.
Important: If you do not hear these 6 beeps, you must start over at step 1.
! Failure to follow this exact procedure can result in erratic lock behavior.
Here is the programing guide if you do not have access to your original one:
http://www.alarmlock.com/images/pdf/DL2700_OI209A.37_PROG.pdf
This is the simplified user instructions: http://www.alarmlock.com/images/pdf/DL2700_OI209_PROG.pdf
Thanks for choosing FixYa,
Kelly
Posted on Oct 14, 2010
  • 15,935 Answers
Dos it work with the key?
THanks!
Posted on Oct 12, 2010
I forgot my password to unlock that phone how do I unlock it
Hi Yassien, Unfortunately you cannot unlock it as that's the security measure. Your only bet is to wipe and start over...
Before doing this method please be reminded that you should back up all you files first. (search for a desktop software that you can connect to. Since your phone seems to be from asia, maybe this generic connectivity software may suffice.
You connect the phone using a USB cable.
http://microsoft-phone-data-manager.en.softonic.com/
After that, then let`s proceed. Factory settings reset. In standby, dial *#7780# and the phone`s lock/security code (the nokia`s default security code is 12345). This reset restores phone`s original settings. Soft reset. In standby dial *#7370# and the phone`s lock/security code. Warning! Soft/Hard reset deletes ALL your phone`s data! Hard reset (the three key code/reset). Turn off the phone. Press and hold three keys together, the green/talk key, the * key and the number `3`.Then, turn on the phone and don`t let the three keys before you see the nokia hands logo/nokia boot up screen. For 5800 XM or some phone like that. Hard reset need different keys/buttons. The green/talk key, the red key and the camera key/button. The process is the same. You can also upgrade your phone into newly found firmware if there`s any. Install it using Nokia PC Suite and Cable that is compatible with your device and then Presto! You got a bradnew cellphone! Well, most likely. :)
Apr 28, 2016 | Cell Phones
I forgot my phone lock code for my nokia 5230. please give me a solution free of cost
Hi
Just Visit your nearest Nokia Service center (Nokia Care) They will Unlock & provide you new lock code.
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 17, 2011 | Nokia 5230 Cell Phone
Hi iwant get unlock my e63 nokia phone after update it is asking lock code itryied 12345 and 00000 but it is coming error message
Those codes you were imputing are not the correct lock code. 12345 and 00000 are security locks, mostly for when you set a password on your phone so no one else uses it.
If you're looking to unlock you phone to use on other carriers, then you would need to contact your carrier for a "Carrier Unlock code" or find a reputable GSM Unlock website to unlock your phone. Usually they will ask for your "IMEI" serial number which is the sticker behind your phone to unlock your phone.
Good luck
Feb 28, 2011 | Nokia E63 Cell Phone
I use nokia 5800...my phone got locked by fsecure ....i do not remember my password...how do i unlock it...plz help its urgent
Press green + red + multimedia button and turn the phone on at the same time. Wait until the "NOKIA" logo appears. This will wipe your phone memory.
If that doesn't work try this.
Soft reset/reformat - Type *#7370# and the phone's lock code (Nokia default lock code is 12345). Warning!Soft reset wipes the C drive/phone memory!
Hard reset - Switch the phone off. Press and hold three keys together, the green key, the * key and the number '3'. While you are holding these keys, switch the phone on. Don't release these three keys before you see the NOKIA logo.
Warning! Hard reset wipes the C (phone memory) drive.
Feb 28, 2011 | F-Secure Anti-virus Client Security...
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
Aug 15, 2010 | Sentry Fireproof Safe
How do you re-program the security code on a 2007
FORD KEY PADS
  • Enter permanent factory code
  • Press the 1/2 button within 5 seconds to enter programming mode
  • Within 5 seconds enter new code, doors will lock, unlock to verify code, this erases previous codes remotes will also need to be programmed. (MAYBE)
KEY PADS/REMOTES
  • Insert key, turn ignition off-to- on eight times in succession, ending with key in on position doors will lock, unlock to verify in programming mode
  • Press any button on new remote, doors will lock, unlock to verify
  • Do the previous step with the second remote, doors will lock unlock to verify.
  • Turn ignition off. Doors will again lock, unlock to verify.
NOTE-Some vehicles use 5 turns of the key instead of 8
Jun 05, 2010 | 2007 Ford Explorer Eddie Bauer
Tocco lite phone freeze deactivate fail
here is some info on PUK codes:
try taking battery and SIM out waiting 15 seconds and powering cell back on.
In your case I believe your SIM is now FROZEN or locked. You mostlikely will need to purchase a new SIM card.
A PUK code (Pin Unlock Key) is required when you enter an incorrect PIN 3 times. After entering the wrong PIN 3 times, the card will be locked and you will need to get a PUK code from your service provider to unlock it.
If the wrong PUK code is entered ten times in a row, the SIM card becomes invalid and you will need to purchase a new SIM Card. The phone will display "PUK blocked call operator".
Mar 04, 2010 | Samsung SYNC SGH-A707 Cellular Phone
Ignition key won't turn to on position, steering wheel does not appear to be locked
if you have a standard, put it in neutral. if automatic, park or neutral.
Nov 25, 2009 | 2004 Volvo XC70
How can i unlock my samsung tocco lite (S5230) to any network for free please ?
With working sim in phone, go to keypad and enter *2767*3855# and wait, this will fully reset phone so ensure you back up anything on it first, during repowering up remove battery and insert sim from other network then turn back on, phone should now be sim lock free. As always this is at your own risk.This will likely work with other Samsung phones
Aug 21, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Code locking of siemens mobile phone
Siemens Mobile Secret Codes:
C25:
SP unlock *#0003*(secret code 8 digits)#
*#0606# shows you Secret Code, but only without SIM Card.
*#06# for checking the IMEI (International Mobile Equipment Identity)
How to change PIN:
**04*old PIN*new PIN*new PIN#
How to check simlock status
*#0606# and then press left soft-key, you will see strange characters, then text ("brak blokad"). If you see for example 260-02, it means the phone is locked to Era GSM. In older models you can use *#06# and see the same information after clicking on left key (you will see IMEI and software version).
S4:
Monitor Mode - how to activate:
Press left soft-key, then 9 (SET UP) 8 (Phone Status). You will see IMEI number, then press left soft-key and in order 7684666 and red phone at the end (monitor mode has been activated). To read information from Monitor Mode - press left soft-key, then 5 (GSM SERVICE) and 6 (Monitor). Monitor mode turns off when you switch off the phone. You must activate it again if you want.
How to see date of software:
Press left soft-key, then 9 (SET UP) 8 (Phone status). You will see IMEI number, then press twice left soft-key, 98, left soft-key, 7684666, red phone (activates Monitor Mode), left soft-key, 56 (turns on Monitor Mode), left soft-key, 98, left soft-key, 7684666, hang up (red phone) >abck to "normal" and then left soft-key, 56.
S6, S8:
If you add to phonebook under 'own phone number' +12022243121 with namez (for example MMI), then you will see something smile.gif
S10, E10:
In phonebook enter +12022243121 as your own phone no. You will see a picture with sun, two palms and greetings.
S15e:
Monitor Mode:
Code: *#7436267*8378# (*#SIEMENS*TEST#)
Hold red phone button until it code disapears.
Menu 3.3.4 Choose frequency.
Menu 3.3.4.1 Automaticaly.
Menu 3.3.4.2 Choose GSM-900
Menu 3.3.4.3 Choose GSM-1800
Menu 10.1 MS info
Menu 10.2 Soft date
Menu 10.2.1 Software version.
Menu 10.2.2 EEProm version.
Menu 10.3 Tst and product info.
Menu 10.3.1 Handware data.
Menu 10.3.2 Date of manufacture
Menu 10.3.3 Service date
Menu 10.3.4 Date of repair.
S25:
Enhanced Full Rate
*#3370# turns on
#3370# turns off
Haft Rate Mode
*#4720# turns on
#4720# turns off.
Languages:
*#0000#+green phone - choose automaticaly
*#0001#+green phone - English
*#0030#+green phone - Greek
*#0031#+green phone - Netherlands
*#0032#+green phone - French
*#0034#+green phone - Spanish
*#0039#+green phone - Italian
*#0049#+green phone - German
*#0090#+green phone - Turkish
How to change PIN2?
**04*old PIN2*new PIN2*new PIN2#
What is my software version?
Menu 8-8-2 press left-softkey when you see IMEI number, or *#06# and then green phone button and then press left soft-key.
How to extend battery life:
IrDA - turn on only when you need.
Turn off automatic network search (6-3)Turn off Vibration alarm.
Resets language to automatic selection : * # 0000 # then Green button
S25, M35, S35, C35
Nov 29, 2007 | Nokia 1100
Trilogy Alarm Lock T2 TRILOGY Digital Locks DL2700 Logo
129 people viewed this question
Top Trilogy Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Trilogy Lock and Locksmithing Expert? Answer questions, earn points and help others
