Question about Toshiba Qosmio G25-AV513 Notebook
Qosmio g25-av513 disassembly
I am a computer repair tech who has received a qosmio g15-av513 for repair, " No fan". i've removed all visible screws but still am not sure how to gain access to the fans or fiind instructions. any help would be greatly appreciated. My email address is pandppc@yahoo.com.
thank you, Paul
Hi Paul have a g25-av513. First disconnect and remove both hard drives and the battery. In the battery compartment there is a small screw you need to remove and in the hard drive 2 bay there are 2 f8 screws that need to be removed as well. In all there should be 17 screws that need to be removed before you can pop the back cover off. When removing pay close attention to the connectors attached to the underside of the back cover. be careful not to pull to hard or you may tear the connectors which are very thin wires. First you have to remove all the screws on the underside of the laptop. The screws are marked f8's and f16's the longer ones are the f16's of course. I have taken mine apart several times already due to a boot up shut down issue which I believe is related to the modem board underneath hard drive 2. It seems that when ever I disconnect and reconnect this board my power shut down issue disappears. If it happens again I'm going to remove i all together and see if that takes care of my problem.
Posted on Jan 25, 2009
Hi I am having the same problem; my fan is making a lot of noises and I need to gain access to the interior of my Qosmio G25-AV513 to either clean the fan or replace it, thanks.
Posted on Jul 06, 2008
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Hi i have problem with toshiba qosmio g25-av513 when i power on its show clear QOSMIO monogram and then start show saverl difrent colurs lines i try with external monitor show same .pls help me to fix this...
You can try downloading the most recent video drivers from the nvidia web site and installing them.
Other than that you would probably need to contact Toshiba tech support. Based on the information you provided it sounds like your video card is having a hardware issue. It's the reason you see the same lines on both monitors.
Apr 10, 2011 | Toshiba Qosmio G25-AV513 Notebook
Spilled Water on Toshiba Qosmio G25-AV513
If you are pretty good at computers then you can open up the computer and see just how bad the damage is. You may need to replace the keyboard, or a few parts of he mother board. If it was water I think you would have more of a chance, but the sugar will definitely cause problems if it hit any circuit boards. Your best bet is to take out your hard drive, make it an external hard drive and get a new computer.
Dec 26, 2008 | Toshiba Qosmio G25-AV513 Notebook
No hotkeys on my G25-AV513
Usually on Toshiba notebooks, they have a memory resident program on their call fkeys. If it isn't installed on your computer, you can download a new one from Toshibas support website.
Jul 20, 2008 | Toshiba Qosmio G25-AV513 Notebook
Qosmio G25-AV513 Case
I have not verified this myself yet, but I will this week. Here is the link: http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/comment-page-1/
Click on the appropriate laptop. The pictures are very helpful when clicked on.
Jul 01, 2008 | Toshiba Qosmio G25-AV513 Notebook
Removing dust from Toshiba Qosmio G25
I just found this online. It might help you. After choosing the appropriate laptop, Make sure to click the pictures to see the editing arrows and circles that show where to unscrew and what to unplug. http://www.laptoprepair101.com/laptop/2006/02/04/toshiba-laptop-disassembly-manuals/comment-page-1/
Apr 29, 2008 | Toshiba Qosmio G25-AV513 Notebook
Removing dust
Yes.. First of all you are entitled to open the case only if your lapotop is not covered by any means warranty.. If you open it when it has a warranty, the warranty becomes void.. and moreover there are many complications n opening it.. so i suggest you to give it to a system engineer.. but if u want to do it by urself.. i shalll tell u the steps.. mail me..
Mar 12, 2008 | Toshiba Qosmio G25-AV513 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
631 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
