Question about Toshiba Satellite M35X-S349 Notebook
Toshiba laptop will not turn on, screen is completely black
I was surfing on the internet when the screen went black. I manually restart it, and nothing happens, the screen is just blank and there's no whirling of the fan like it usually is. So I restart it again(the ac adaptor is plugged in at this point into a surge protector), and the logo comes on and the fans so I'm relieved. I leave it on to go to the grocery store, and when I come back the screen is black again. The 3 lights are still on, so I just unplug the adaptor to see if anything changes, but the power button is still lighted, so I start the restart processes. Nothing worked so my uncle opens up the laptop, and says that the motherboard is fried because the dvd rom drive won't eject and there are no sounds coming from the laptop, not even the fan even if the power light is on. I kind of want a second opinion before I go off and buy a new laptop, as I'm a poor college student. Did I electrically short circuit it or something?
  • 3 more comments
  • psychoidiot Jun 01, 2008
    I haven't but I don't have an s-cable. But I do have automatic sign on the moment the windows open, and my friend says they can't see me. When my brother broke a previous laptop monitor where we couldn't see anything, this method proved that the computer still worked.
  • Anonymous Jul 05, 2008
    cannot turn on...no lights..nothing
  • dawndianne Dec 19, 2008
    My toshiba lap top will not turn on... blank black screen.....I can hear the fan start but thats it...Does this mean I need new battery?
    desparate for help......
  • Anonymous Jan 25, 2009
    the screen is black but all the rest of stuff is working
  • kathie pope May 11, 2010
    have you tried to run the laptop with an external monitor yet? if you plug an external monitor into your laptop and it works then it might be your graphics card.
Don't pay attention to your uncle. I had the same problem. Blue ring, power lights on. Sometimes the laptop would come up after a few minutes and then would freeze. It is a power problem. The AC jack may be broken and, most likely, you need to get the MAX1632A power controller (a 40-48 pin black IC next to the AC jack) resoldered too (get someone qualified to do it, with the right soldering station for surface mount work). Look for a complete answer at
http://www.laptopka.com/2006/04/04/fix-most-common-problems/all-comments/#comments
Comment #202, by Jerry.
I followed his instructions and got my laptop back from the dead
Alfonso
Posted on Oct 18, 2008
I have a Toshiba satellite the screen went black it is still running but sc4een black. Have tried many restart options need help
Depending on the model the screen may have failed, the inverter failed or the GPU failed. Plug an external monitor in, power up the laptop and if you get a picture, your screen failed. If no picture the Nvidea GPU has failed.
Dec 21, 2016 | Toshiba Computers & Internet
Toshiba satellite pskoqu screen blanking
Please check the air vents (inlet and outlet) and clean them up using a canned air, and use an external monitor to test this laptop. If the problem is not solved, then your laptop's GPU/motherboard is dying.
Mar 09, 2014 | Computers & Internet
My screen went black on my toshiba satellite C655-S5132 laptop when I turned it on after the toshiba came on. It was working fine until I tried to connect a projector to it and mashed some of the F...
sounds like an irq conflict after trying to install projector. you will have to boot into safemode and go grom there. dont know what op system your using . windows used to be f8 on start up but thats changed now too.
Oct 09, 2017 | Computers & Internet
My toshiba A200 screen occasionally turns black and music also stops. When i try manually restarting my laptop, sometimes it works but most of the time it doesnt boot at all. Sometimes it doesnt even go...
This sounds like a hard drive is, or has failed. Either that or the RAM (memory has gone bad)
Did you let the laptop overheat? Was it left on for a long time? Or is this just an old machine ?
I would replace the hard drive, and reload the operating system, that is if you really want to keep the laptop. If that solves it great! Also, did you notice if there are any "beep" noises, or error messages when it acts up? Often times, you can go on the internet and find out what the messages mean.
Jun 17, 2009 | Toshiba Satellite A200-0ET00X Notebook
Nothing appears on my monitor
Might be dead... try to leave it off for w while before trying again. check all connectors and if it still faisl to work your going to have to get a new one. Before that check your warranty and dealer and se if anything is coverd. best of luck
May 25, 2009 | Toshiba Satellite Pro 6100 Notebook
I dont know how to set back to factory settings i was updating the settings and my internet went off and now i only have half my setting whick means i cant download them back please help
Just press f10 after you restart and it will recover the factory settings from drive d, you should then have your factory settings in place and just follow any instructions on the screen everything should be fine then
Feb 28, 2009 | Acer Aspire One PC Notebook
I re-started my toshiba A135 laptop, and the screen went black
There are dozens of possible root causes for your problem I guess.
But exactly the same happened to me in fact on a packard bell laptop. After my son forced it to reset, it didn't start again. Only one led was lit. After a long search I found that the battery had died and this prevented the laptop to start even when the power supply was plugged in.
Try this: remove the battery, connect it to the power supply and restart.
Hope that helps
Jan 24, 2009 | Toshiba Satellite A135-S2276 Notebook
Acer aspire laptop 3690 display black
Try unplugging the computer from the power supply,,and remove the battery,,,then replace battery and plug into power supply again,,,and try to restart.
Jan 19, 2009 | Acer Aspire 3680 Laptop
Laptop works fine until the screen turns complete black...
Well you can look if you pluged cable into GeForce not into motherplate second you can try it on another laptop if it works well you must repair your computer
Dec 31, 2008 | Toshiba Satellite P100 Notebook
Blank/black screen
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Oct 12, 2008 | Toshiba Satellite A55-S106 Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
5,664 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
