Question about Zanussi 24 in. DE6965 Built-in Dishwasher
Al 5 - Zanussi 24 in. DE6965 Built-in Dishwasher
  • Zanussi Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Oct 12, 2010
Alguien k me ayude necesito el orden de los cilindros de una 2004 f150
si senor cylindro 1 2 3 4 estan en el lado del pasajero .con uno siendo el primer cilindro por el lado mas serca a las correas... 5 6 7 8 estan al lado del chofer con 5 siendo la posicion mas frontera del vehiculo.mismo que al lado de las correas. suerte
Jun 28, 2015 | Cars & Trucks
LOST DIRECTIONS.. DONT KNOW HOW TO SET ALARM..or use this clock..CAN YOU HELP ME
You can download the manual for free using this link:
http://dl.owneriq.net/8/82dd8645-ef03-4b41-9b07-5a6b02655a1d.pdf
Setting and Using the Alarm
1. Press the AL SET button. The time will flash.
2. While the time is flashing press the HOUR button until you reach the correct hour. Then
press the MIN button until you reach the desired minute.
3. After 5 seconds the alarm set time will stop flashing and it will be programmed, or you may press
the AL SET button.
Note: The PM indicator also applies to the alarm. You can review the alarm setting anytime by
pressing the AL SET button.
4. To activate the alarm you may choose one of 3 wake options:
a. To wake to BUZZER press the AL MODE button once.
b. To wake to a SOUND press the AL MODE button a second time. It will set to the last
sound you listened to. If you wish to change it press the sound you wish to
wake to and then press the POWER button.
c. To wake to RADIO press the AL MODE button a third time. You may leave it on the
current station or adjust the TUNER.
Note: A green LED will appear next to the wake mode selected to indicate the alarm is set.
Thanks.
gylacz
Aug 19, 2011 | Homedics SS-4000 Clock Radio
Como va conectada la corriente y la tiera al capacitor
Del corriente de la bateria al positivo del capacitior. De la tiera de capacitor al positivo o corriente del amplificador. Bueana suerte.
Feb 14, 2011 | Power Acoustik Pcnc3.0f 5 Farad Digital...
We have a Sharp Model AL-1631 unit that keeps running but doesn?t make copies. Any idea what is wrong and how to fix it? Thanks.
When these Sharp AL series machine just run and run it means they are low or out of toner. This is especially true if you are hearing a light thump thump noise while it is running. Just let it run and after 5 minutes or so it should shut down and then replace toner light should come on. This is the small red light that looks like a stack of 6 dots.
Either replace the toner or have your existing toner refilled.
Good Luck and Thank You for using Fixya.
Sep 17, 2010 | Sharp AL 1631 Copier
Can you help me for may copier sharp AL 1216 with the error code H4
Press C, Auto, C, Auto keys in that sequence whole process should be within 5 sec, enter 14 print.
Nov 12, 2009 | Sharp AL-1217 Copier
Sharp AL 1631 Grayscale Copier Placement of Shutter Film strip
you may have removed the toner receiver strip.you have to removed the drum from the assembly.you can remedy that with .5 inch masking tape.
Jun 09, 2009 | Sharp AL 1631 Copier
Dejo de funciona disketera 5 1/4
Has verificado los settings en el BIOS?
I que el cable de data no este al-reves?
May 17, 2009 | Gigabyte GA-6VX7B-4X Motherboard
On the harp al-1631 what does the flashing f then 5 mean ?
*** ALWAYS DICONNECT POWER SOURCE BEFORE REPAIRS****
Check and clean white stripe, make sure it is clean and white.
Check and /or Replace the exposure lamp, they go bad and cause F-5.
If lamp is good, replace exposure lamp sensor.
Check connector ( flat cable) connections to scanner brd.
Replace scanner brd ( board) if defective.
If scanner brd is good, replace power brd.
Jan 18, 2009 | Sharp AL 1631 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
Zanussi 24 in. DE6965 Built-in Dishwasher Logo
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
