Question about Canon PIXMA iP3500 Printer
Is it possible to use printer with black ink cartridge only? Printer: canon ip3500
  • 117 Answers
Yes u can.
In the Printing Preference window, Choose the media type (paper type) as plain paper and check the Grayscale printing mode.
Posted on Oct 12, 2010
Paper is not printing
Since you are asking about a Canon Pixma ip3500, I would guess that the ink cartridge(s) is/are dried out, empty, or clogged. Try swapping out with new, fresh Canon cartridges and see if that fixes the problem.
Also, be aware that it is extremely ill-advised to use only refilled or "compatible" cartridges all the time in the case of inkjet printers (of which the Pixma line of printers is an example). The reason being that the refilled and "compatible" cartridges use plain ink while the OEM cartridges use a mix of ink and lubricants so as to keep the ink delivery system functioning to peak efficiency and help to keep the system clear of clogs. Therefore, if you have recently put in a new cartridge but it is yet another refill, swap it out for a real Canon cartridge and then try using the "clean the printer" function to try to clear out the ink nozzles. If you don't feel comfortable doing this or you are unsure how to accomplish this task, get in touch with a local computer or printer repair shop and they will gladly resolve this for you.
Jun 05, 2015 | Canon PIXMA iP3500 Printer
My cannon ip3500 will not print in color ink tanks are full
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Thank you for using Fixya
Aug 11, 2011 | Canon PIXMA iP3500 Printer
My canon iP3500: Black print comes out patchily, despite many attempts at deep cleaning, Each time I deep clean, a couple of pages come out with the black print OK, then it goes patchy again.
It sounds to me like your cartridge nozzles are clogged. That's more common with recycled or refilled cartridges, but it can also happen with new cartridges if they are older. If you just purchased the cartridge you could try to return it. Otherwise, I would try to continue deep cleaning and nozzle checks until it starts to print. It takes a lot of ink, but sometimes that's the only way to get it to print. Usually it will work eventually. Do a nozzle check in between each cleaning and deep cleaning.
Feb 06, 2011 | Canon PIXMA iP3500 Printer
All ink is work the black wont work
It seems simple enough, but this is one of the most effective ways of fixing printer cartridge error. Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached.
To reattach the cartridge check the following steps :
turn on the lid of the printer and then remove the cartridge from the printer head.
Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report.
Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | Canon PIXMA iP3500 Printer
Canon ip3500 does not print black but colour ok ... whats up ... how to fix
1. this could be a clogged print head at the black cartridge. the head needs cleaning or the jets have clogged ports and cannot pass ink due to hardened ink.
This may require a print head replacement.
2.If you have recently place a new cartridge in the print slot check to see if you didn't leave the protective tape on the cartridge.
Apr 20, 2010 | Canon PIXMA iP3500 Printer
My printer doesn't print black. Help! Any suggestions! I replaced the ink cartridge already.
Hello how are you.
Toy can do reset to inks with program it called iP Tools this can do many good things to printer please go to link I gave you to see
Hope this good for you thank you.
Usai
http://tricks-collections.com/resetter-printers-canon-pixma-ip1000-ip1200-ip1300-ip1500-ip1600-1700-ip1880-ip2200-ip3000-ip4200-ip5200/
Mar 10, 2010 | Canon PIXMA iP3500 Printer
The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
Oct 03, 2009 | Canon PIXMA iP3500 Printer
Black not printing, other colors fine, replaced cart and deep cleaned several times, no result
Assuming genuine ink cartThis worked for me on a HP printer 1.Try print black text ,and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Good Luck Inkypete
May 01, 2009 | Canon PIXMA iP3500 Printer
Need to know how to change ink cartridges, need manual
Both of your answers are at the below link.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=257&modelid=15600#DownloadDetailAct
hope this helps
Apr 13, 2009 | Canon iP3500 Photo Printer
Canon PIXMA iP3500 Printer Logo
318 people viewed this question
old marine
old marine
