Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blinking green timer light.cannot power up - Mitsubishi WS-65513 65" Rear Projection HDTV
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help. I WILL GIVE YOU AS MUCH HELP AS I CAN.
SD TECH
Posted on Oct 12, 2010
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
Sep 03, 2014 | Mitsubishi XD221U New
Green LIght Blinking
Does the led ever stop blinking? No ..well in that case generally this indicates a standby voltage problem...if all those voltages ok then the cuircit known as digital module is at fault. also make sure the lockout has not been activiated. i really dont think it could but to unlock hold menu button down for 10 seconds. After all that i believe it would be a bad digital module
Willie@fordtv.com
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Blinking timer light Mitsubishi wd65735
Based on the service manual:
1)Fast Blink Green= Initialization (40 - 60 seconds) (AC Off)
2)Slow Blinking= Green Power On Timer is set.
www.aaatvservice.com
Aug 10, 2014 | Televison & Video
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Blinking Green Timer Light
I suspect the lamp area is VERY dirty as is the cabinet's filters and fans. This causes great stress on your tv and lamp. Take the time to clean all of them fully. Is the unit in a dirty area? or in a high temp area? DLP's dont like high temp or contaminated areas as they are NOT air sealed units.
Aug 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
Jun 24, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
22 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
