Question about GE 46GW 948 46" Rear Projection Television
GE Rear Projection TV
I apologize, I don't know what model, except that it is a GE 46 inch. If someone has an easy way to tell what model I will post.
TV powers on, with gray screen. I can hit menu and bring up all the menu options and up until today, I could go into the Screen Menu and just go into the calibrate green, red or blue and then exit and it would kick right on. Now, not even that works.
Also, related? Sound is very touchy, I think this might be fuse related, intermittently if you try to turn the volume up or down after it's been on awhile, it will go to all static. We have surround sound hooked up so it hasn't been an issue, unless it's related...
  • 125 Answers
The model is on the back in a label it may be ptk195
or ptk169 by the way what is the problem
Posted on Aug 20, 2008
Have someone check to see if the Horizontal output transistor is shorted==that and the high voltage transformer were common failure parts in this model
May 23, 2012 | GE 46GW945 46" Rear Projection Television
I have a jvc 46 inch lcd tv model LT42E478 and the picture has a lot white color i have tried checking the connections and the menu setting in picture mode i even set it back to factory defaults have you...
Yes and in several brands it is not uncommon= the main board and others communicate and control this function= means it could be anywhere--not easy except by subbing boards to find---Shops will either do that or use a scope and expensive signal generator to trace the problem.
Apr 09, 2012 | JVC HD-56G886 56" Rear Projection HDTV
RCA 46 inch convergence problem
AM sorry, but can you provide your model number TV and chassis please?. I will tell you location parts. Thank you
Jul 14, 2008 | RCA P52926 52" Rear Projection Television
Projection tv
I wonder if yu are still dealing with this problem so I can help you
Jun 21, 2008 | GE 46GW 948 46" Rear Projection Television
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
GE projection tv
Apr 05, 2008 | GE 46GW947 46" Rear Projection Television
46 inch rear projection tv bulb replacement model number 46gw944
The tubes are most likely not the trouble,sounds like you have a bad screen asy part number is 204809,must use the generic,Thomson discontuned this part.
Feb 05, 2008 | GE 46GW945 46" Rear Projection Television
Won't turn on
tv chassis ctc 195 , hvt transformer, digital conv, power supply,
Dec 04, 2007 | RCA P46921 46" Rear Projection Television
Focusing coil
What is the set doing or not doing?.....Why do you say the focusing coil ?............What is a focusing coil..........?
Please provide the service # off back of TV........T.
Dec 02, 2007 | GE 46GW947 46" Rear Projection Television
Open Questions:
See all GE 46GW 948 46" Rear Projection Television Questions
GE 46GW 948 46" Rear Projection Television Logo
99 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
