Question about Makita 3/4" Vsr Hammer Drill
Diagram of side handle for makita rotary hammer drill
  • Makita Master
  • 7,733 Answers
How to remove wires from the switch from makita hr2450 hammer drill
Use a fine jewellers screwdriver or thin stiff wire in the small holes next to the wire holes.
Dec 07, 2012 | Makita HR2450F Rotary Hammer
MAKITA HR3000C HOW DO I REMOVE THE HAMMER/DRILL MODE CHANGE SWITCH
The big control levers off, but the small one only comes off once you have removed the screw and have it in the down position.
Sep 27, 2012 | Makita HR3000C Electric Rotary Hammer
Makita
possible broken spindle or gear in the gear case
Aug 26, 2012 | Makita HR3851 Electric Rotary Hammer
Makita HR4041C rotary hammer drill
There is no tension to adjust on the Makita HR4041C rotary hammer drill. If you are not getting the hammer action you think you should be it's possible the o-rings on the piston are damaged or not lubricated or the striker is stuck or not lubricated enough to work properly. If you're having problems with the bit turning, there are several gears that turn the bit that could be slipping or are stripped. If you need a manual or brakedown of the tool, one is available on www.makitatools.com. The insides of rotary hammers are fairly complicated so be carefull of what goes where if you decide to take the tool apart to check for internal problems.
Aug 26, 2012 | Makita HR4041C 1-9/16" Spline Hammer
Makita hammer drill hr 3000c has stopped hammering need strip down diagram to locate part fault
go to makitausa.com and you can download a parts schematic there, let me k now if you need more assistance.
Aug 26, 2011 | Makita HR3000C Electric Rotary Hammer
So does the hr200 work as a miny jack hammer or just a driil, can i buy a diffrent bit for that type of model to jack hammer up a little concrete
This is an older, discontinued model Makita that only works as a hammer drill. It does not have the dial selector the newer models have to switch from 'drill' to 'hammer drill' to just 'hammer'. If you need, there's a parts breakdown and user manual available at:
http://www.makitatools.com/en-us/Modules/Tools/ToolSupport.aspx?ID=352
Dec 23, 2010 | Makita HR2010 13/16 Rotary Hammer, SDS,...
I have a makita hr300c rotary hammer drill. take at least 8-9 minutes before hammer kicks in. can you help
it sounds like it needs new o rings and serviced. you can go to Makitatools.com and download a breakdown for this tool, If you are handy and take your time they are not that bad to repair. Let me know if you need more assistance.
Feb 10, 2010 | Makita HR3000C Electric Rotary Hammer
Makita HP1640 hammer drill dual mode - 2 hours
Exchanged Makita HP1640 hammer drill for a new one. The 2nd drill did the same thing in under an hour!! Will return for refund. Instructions say the Forward/Reverse switch must be in a full up or down position for the Hammer/Rotary switch to move; well, it is and the Hammer/Rotary switch still stops at a 1/2 way point between modes. Although I can still use the drill, instruction warnings say not to because it may potentially burn out the motor. I'll have to go with a different brand this 3rd time around. It seems to be a design flaw.
Oct 10, 2009 | Makita Drills
I have a makita hr2455x rotary hammer drill that won't hammer
you need to get that service,
the grease causes the hammering.
and probably too much pressure was applied
to it.
Mar 25, 2009 | Makita HR2455X 1" Rotary Hammer Drill
Depth Rod Question
Depth Rod - A devise mounted on the side of the drill that lets the user know when they have reached the desired depth.
Aug 27, 2008 | Makita Rotary Hammer 240 Rpm, 2150 Bpm, 15...
Makita 3/4" Vsr Hammer Drill Logo
274 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
