Question about Samsung RS2534 Side by Side Refrigerator
Fridge fan has frozen and has stopped. was noisey and stopped when door opened
  • Samsung Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
My f&p fridge freezer E240B is not chilling in the fridge part. I can't find any manuals or help on line for the product. Help please
Andy,
I am not familiar with the frig your referring to. However, MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped.
Oct 11, 2013 | Refrigerators
Refer door left open overnite. can hear it running but fridge and freezer are not cold.and it has run all day. What can I do? .
the fan that blows air from freezer to fridge is probably frozen with ice from all the moist air when door was left open turn off unit and let defrost will see screws where fan is located to help fan defrost us hair drier to free fan when free enough to turn freely turn on unit and push door switches or close door and listen for fan to go on if goes on turn off unit and and continue to defrost till fan and duct [airway ]is clear of ice than turn on and let run -if fan doesnt go on have tested may have burnt out from trying to run while frozen up repair or replace fan and recheck unit good luck
Jun 27, 2011 | Kenmore 94499 Refrigerator
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Freezer fan is noisey and can t find serial number
The number you will need is the model number. On side by side models there are a few places to look. 1- inside fridge on right or left wall. 2- Open fridge door and look up near the top front lip. 3- Open both doors and look on body of fridge under the doors. 4- Fridge door sometimes there is a sticker right when you open. Mostly you are looking for a silver sticker or silver plate. It gives you a model number and serial number. If you need further assistance please mail me back.
May 26, 2011 | Kenmore Side by Side Refrigerator
Frozen food in the refrigerator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 31, 2009 | LG LFX25960ST Stainless Steel French Door...
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Chilled water stopped .chiller frozen in bottom of fridge
SR-32 EMB MODEL, FREEZER OK, BOTTOM NOT COOLING PROPERLY. ADVICE SETTINGS
May 28, 2008 | Refrigerators
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Samsung RS2534 Side by Side Refrigerator Logo
242 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
