Question about Ovens
My problem is a Heating - Ovens
  • Ovens Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Oct 12, 2010
Adjust thermostat
A thermostat only cuts the heating off when the temperature it is set to is reached while the heating is on. If the heating is set to off then the thermostat will do nothing.
Generally you want to think about when you want your heating to come one and off by using the timer and then the thermostat is just used to ensure that you don't waste energy by exceeding the maximum comfortable temperature.
Hope this helps a little.
Nov 22, 2013 | Ovens
Melted plastic on heating coil
you can not remove the plastic safely please replace the heating element
Sep 30, 2013 | Frigidaire (FEB30S7D) Oven
TOP OVEN WORKS OK BUT BOTTOM OVEN DOES NOT HEAT UP
There are a number of reasons why you may find that your oven doesn't heat up, and troubleshooting oven heating elements is not too complicated, so you should be able to manage this in a few hours. When you are trying to decide what is the cause of your oven not heating up properly, you should be able to identify the different problems, and also understand how to repair the oven without too much difficulty. If you find a lot of problems, then you may need to provide a different solution, for example replacing the heating element and fittings completely.
Heating Element is Broken
This is perhaps the most common cause of the oven not heating up. The element inside the oven will not become hot if the electrical connections are damaged, or if the element itself is not working. The heating element can be removed and replaced easily, and this is perhaps a very good idea if you have any problems with the heating system of your oven. Test the heating element by firing up the oven with the door open, and your hand close to the front of the element. You should be able to feel it warming up, so if it doesn't, take of the screws which hold it in place, and then unplug the connections. You can take the heating element to a store and they should be able to replace the part for you.
Hope this help in solving the problem.....
May 17, 2011 | Ovens
How do you replace the bottom heating element
Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element.
To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 09, 2011 | Ovens
Oven not properly heating
If your electric2_bing.gif oven is not heating then you probably have a bad heating lelement in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 06, 2010 | Viking 30" Professional Select Built-in...
Main oven not heating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
heatman101
Dec 19, 2009 | Neff U1721 Double circotherm Electric Oven
Oven heating up slow
heatman101
Nov 23, 2009 | GE Profile JTP18 Electric Single Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
The oven stopped heating but the convection oven function works
heatman101
Jun 23, 2009 | GE Profile JTP18 Electric Single Oven
Replace the upper heating element
hi E mail me model no can proberly sort it. regwoolleu@uwclub.net
Jun 11, 2009 | Ovens
Ovens Logo
35 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
