Question about Radio Shack Pro-97 Handheld Scanner
Programing trunk system
How do i program trunk system
The only way I know to program trunking would be manually one freq at a time unless you can find the software and cable to the unit.
Posted on Jun 03, 2008
Trunk lines r getting hangup always and i'm reseting the system always
Check your firmware on the system.
which kind of phone do you have connected to the stytem, are these all digital phones?, like the ones on your profile picture. do you have programming software for the system. I will then be able to give you some steps to follow for the trunk access mapping and key assignment to the phones.
Jun 01, 2012 | NEC PABX SL1000
How do I program it for triple truncking?
There is no such thing as "dual trunking" or "triple trunking." Such terms are used by manufacturers to indicate the number of trunking systems that a scanner is capable of monitoring. The PRO-95 is designated as a Dual Trunk-Tracking scanner because it is capable of monitoring both Motorola and EDACS systems. Programming a trunking system in to a scanner is a detailed process that requires a bit of research.
For details on active trunking systems in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Once you have the system information you can follow the programming steps outlined in your scanner's operating instructions. If you don't already have the manual, you can download and print it here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-95/pro95.pdf
Bill B
Jul 24, 2010 | Radio Shack Pro-95 Handheld Scanner
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
I am trying to program my Uniden BCT8 to track LTR systems but having problems.
LTR systems must be entered in a specific order so that channel 1 is 1st, channel 2 is 2nd etc...
Are you sure that the BCT8 tracks LTR systems? A Radio Shack PRO 92 tracks all 3 trunking systems (analog) including Motorola and LTR, while some Uniden only track 1, and some don't do trunking systems at all.
Dec 27, 2009 | Uniden BCT8 Base Scanner
How do you program the bc350c scanner
Conventional frequency programming is fairly simple, but programming trunk systems is more detailed and can't be adequately covered in this forum. Please follow the link below - it will allow you to download/print the manual for your 350c, and the manual will walk you through the programming steps.
http://www.uniden.com/pdf/BC350Com.pdf
For a comprehensive database of active frequencies and trunk systems in your area, visit
I hope this helps, but if you have any more questions, please contact us again.
Dec 09, 2009 | Uniden BC350C Base Scanner
New batteries but remote won't click the door(s) or trunk. Ron
try programming the remote again, here is how u do that. if this doesn't fix the problem the remote may be defective, if you need a new one try ebay, they are very cheap to buy there.
Note: Existing keyless remotes will be erased with this procedure.
Existing working remotes will have to reprogrammed also.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
Nov 30, 2009 | 1994 Pontiac Grand Prix
Mitel sx-20 trunk interrogation function codes
From a DTMF station set installed as the test line on equipment #1, go into trunk group programming (Command #66)
The SX-20 display will show programming registers.
A B C D E F G H
A,B = Trunk equipment Number (1st trunk should be displayed)
C = Register 1
D = Trunk Group Membership 0 = Incoming only
1 = Group 1
2 = Group 2
3 = Group 4
4 = Group 4
E = Trunk Type 0 = Standard CO Trunk
1 = Dictation Trunk
F = Reversal Meaning 0 = Not Incoming of Disconnect
1 = Incoming Call
2 = Incoming Call or Disconnect
G = Disconnect Timing 0 = 60ms
1 = 500ms
2 = 1.5 sec
3 = 4 sec
H = Start Type 0 = Loop Start
1 = Ground Start
Move to the appropriate register using the ENTER/NEXT function (star key).
Change the data as required.
Exit programming (# key)
Hope this helps!
Mar 25, 2009 | Lands Phones
HOPKINSVILLE KY. POLICE DEPT. CHANGED TO A
Unfortuantly the pro-82 is not a trunked scanner, it's only a vhf/uhf scanner and cannot pickup trunked systems. You need to replace it with atleast a pro-95 to pick up trunked systems. If you need your manual for the pro-82 follow this link.
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/2000315_PM_EN.pdf
Feb 19, 2009 | Radio Shack Pro-82 Scanner
Programming Motorola type II system
The BR330T is an analog only scanner. Prince William County's system is 800 MHz digital, which your scanner cannot receive. You can receive the fire department simulcast of "5A" (their fire dispatch channel) on 154.325 in analog mode.
Dec 28, 2006 | Uniden BR330T Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
217 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
