Question about Frigidaire ATF6000ES Front Load Washer
E21 - I keep reading about cleaning the filter but....
I keep reading about cleaning out the filter, but my problem is that I having awful time getting the clamps off the hoses. I can only get access from the back (how from the front????). The clamps are hard to reach, take a large amount of force to open and are not facing the best way.
Since it is so hard I don't want to just disassemble all of the hoses.
Can someone give me more specific guidance.
Thanks
  • 868 Answers
Have a qualified repair man repair this problem ,you can cause more problems trying to do it your self.
Posted on Jun 03, 2008
My Toshiba washing machine model AW-A800MBK This have 4 LED lights, Now machine running some time drain and showing LED 2,3 glowing and then machine stop, What is the problem with this machine?
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times. E2 error code aw 8990st toshiba wash Washing Machines
Mar 13, 2018 | Washing Machines
My washing machine has a code e21 what do that mean
Please read description carefully about error code
Logik Washing Machine Error 21: "E21"
Error Code Definition: Washer has not drained in allotted / time washer not draining.
How To Clear Error Code:
-Check that filter is not blocked or kinked
-Check drain hose is clear of any blockage or kinked
-Check wires to drain pump
-Check drain pump is not faulty
-Check level sensor and switch
-Check wires to level sensor
here is link for more about your all error code which will may helpful in future, LOGIK Washing Machine Error Codes How To Clear
here is video which helpful regarding solve and understanding error.
Mar 16, 2017 | Washing Machines
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Jun 19, 2015 | Frigidaire Washing Machines
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
E21 error is showing on my electrolux EWF14811 washing machine. What does this mean and how do I clear it?
E21 means a problem with the water draining.
Could be defective: drain pump, pressure switch, wiring, current leak between heating element and ground and finally main board.
Also could be drain filter or drain tube (kinked or clogged) and leaks from water circuit on pressure switch.
Dado
E2 error code aw-8990st toshiba wash
E21: Lid open
E31: Load imbalance
Hope this helps
Jan 25, 2014 | Washing Machines
My AW-1190S toshiba washing machine was showing error code E2-3
My Toshiba aw1190s shows error code E21. What the problem.. Tq..
Nov 22, 2012 | Washing Machines
My washing machine keeps coming up with an E21 error code
Hi.
The definitive answer depends on the machine model numbers. In Frigidaire, Zanussi, OKO, Electrolux, SMEG and other machines E21 means that there is a drain problem. The repair is carried checking the drain hose at the back and accessing the drain filter (in front at the bottom with most machines from those manufacturers. For some general troubleshooting see : My washing machine does not drain.
Regards.
Ginko
Aug 30, 2011 | Washing Machines
Eiflw55hmb error code e21
Ok you have a front load washer made by Electrolux. Prbably says Fridgedaire.
E21-water not pumping out fast enough.
There could be a clog in the filter or a kinked hose. Check all the hoses and the filters. Some models have inline filters just before the pump. Filters are designed to protect the pump.
If you need further assistance please feel free to contact.
Jul 19, 2011 | Washing Machines
98 blazer 4.3 4x4. runs very rough. scan code reads p0300 so far i have changed fuel filter, fuel pump, fuel injectors, egr valve,cap an rotor, plugs an wires, took the cadillac converter off. to see if it...
ethanol gas problem. add a can of SEAFOAM to tank of Premium gas. change fuel filter after 100 miles. then add SEAFOAM 3-5000 miles to keep fuel line/system;emissions, and valves clean of ethanol goop and water which is created by this awful ethanol mixture.
Aug 31, 2009 | 1998 Chevrolet Blazer
Frigidaire ATF6000ES Front Load Washer Logo
154 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
