Question about Samsung CLP-510 Laser Printer
Can't reset counter for new transfer belt, menu won't progress
  • 2,069 Answers
Start up the machine while pushing the buttons "online" and "cancel"
--You will see the message "Download mode press online key"
Press about 15 times the "menu" key, until
--You will see the message "Uncheck consumable mode"
Wait..
Press about 15 times "menu" and 5 times "enter"
--You will see "Press access key"
Press a few enters
Press 3 times "cancel"
Go to the EDC mode
-- you will see "press access key"
Press "cancel"
Go to maintenance and initialize the parts you like to reset.
otherwise indicate whether it is saying something about the transfer belt...
Posted on Oct 12, 2010
How do you reset chip for transfer belt Samsung 3300
Reset counter in service Tech Mode:
[Menu] [Back] [Left] [Right] [OK] [Stop] [Menu]
Data Setup - Clear Count (enter password - 1934) - Transfer Belt
Reset toner count you can here:
http://fix-bay.com/fix-proshivka-samsung-clx-3300-3302-3303-3304-3305-clx-3305w-3307w-skachat-v12/
Nov 25, 2015 | Samsung Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
All three lights blink rapidly. The computer says it cannot communicate with the printer. When I plug the USB into the computer the computer doesn't acknowledge that anything was plugged in. If I...
It sounds like your main board (the brains) in the printer is fried (I got the same problem with mine). That part (when purchased new) costs so much, your better off just getting a new printer, and it's not your typical user serviceable part (hard to remove, many wire/plugs going to/from it).
The problem with replacing it with a used part, is that the used circuit board will still have the consumable counters in it set to old values from the printer is was pulled from, and NEW or RE-Chipped consumables will be needed to reset those back to zero again (not just the toners, but also the photo drums, fuser, and transfer belt). So, if the used board was connected to "old" consumables (nearly depleted), you won't be getting too many prints before it's asking for either new toners, photo drums, fuser, or transfer belt. The fuser and transfer belt cost upwards of $175 or more each....
How it works is like this, according to Okidata's Tech support guys. When you put a new "consumable" (toner, photo drum, fuser, transfer belt) into the printer, that main board resets the counters AND THEN it immediately blows a fuse (not a regular fuse, but a microchip fuse) in that comsumable so it can never reset the counter for that consumable again. When that consumable's counter reaches it's predetermined number of prints, the printer refuses to print until it is replaced (or it is "re-chipped" with a new fuse).
They make toner refill cartridge chips, and I think even a photo drum kit (seen it on Ebay). But I haven't found anything that would rest the fuser or tranfer belt. Let me know if you find something to reset the fuser or transfer belt.
Jun 10, 2011 | OKI C3400n Laser Printer
Samsung clx-2160 printer is showing transfer belt error. how do i sort this
transfer belt (and other consumables) will reset follow this procedure:
1. go in diagnose mode:
menu - # - 1934 - menu
2. in tech mode -consumables counter - transfer belt -reset
3. after 20 sec. power off and power on
When transfer belt count 60.000 image need to reset.
good lock!
May 28, 2011 | Samsung CLX-2160N All-In-One Printer
I was getting a message that the transfer belt needed to be replaced and I replaced it. But the message won't go away.
try this:
1. Press # sign; then 1934
2. Press MENU
3. Arrow to Tech Mode (not User Mode); press OK
4. DataSetup; move arrow to Clear All Memory
5. Clear All Memory; press OK
6. Choose coonutry; press OK; will erase and print out configuration report; clearing the transfer belt error.
This wipes out the counter on the Transfer Belt. Clear All Memory means all your settings are wiped out. This also reset all the counters EXCEPT the imaging unit counter.
Trust this helps. Please vote.
Dec 14, 2010 | Samsung CLP 300 Laser Printer
Put in a new transfer belt but can not reset the counter
The transfer belt always needs to be manually reset.
*When this part is replaced, it is necessary to reset the "life" used stored in memory. To reset the fuser and transfer roller life usage from the printers control panel: a. From the main menu select, Menu-Setup --> Maintenance --> Check other. b. Select the appropriate part name from the list by using the Up Scroll and Down Scroll buttons c. Select Reset.
Whit Item, Inc.
Nov 30, 2010 | Xerox Phaser 6100/BD Laser Printer
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
Transfer belt (and other consumables) reset follow this procedure:
1. go in tech mode:
Press consistently menu -> # -> 1934 -> menu
2. in tech mode find ->consumables counter -> transfer belt ->reset
If this not help try this:
1.MENU # 1934 MENU
2.Tech Mode (not User Mode)
3.DataSetup
4.Clear All Memory
Oct 27, 2009 | Samsung CLX 3160fn All-In-One Printer
XEROX PHASER 6110 MFP REPLACE TRANSFER BELT MESSAGE
If you have replaced the Image Transfer Belt, and the printer still does not work, you will need to reset the counter. Xerox would not tell me how to do it, so I did some investigating.
1. Enter Service Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press Enter
6. Enter Password 1934
7. Arrow to Transfer Belt and press Enter.
The display will show Clearing Counts and then return you to the Tech Menu. Press exit several times to exit the Tech Menu and then power cycle the printer.
May 18, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Need to reset counter for transfer belt
to reset the counter on the toners and transfer belt see:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
496 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
