Question about LG GC-051SS Compact Refrigerator
Not cooling but fan is running - LG GC-051SS Compact Refrigerator
How to access the LG refrigerator cooling fan
Posted on Aug 03, 2012
  • LG Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 12, 2010
How do I fix cooling fans that run when car is off
Replace the fan relays. The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
High speed The Radiator Cooling Fan Motor Relay is located: Under hood, driver side, front side of strut tower, mounted in relay panel
Application:
Low speed,here's a new part.
http://www.autozone.com/cooling-heating-and-climate-control/relay-radiator-cooling-fan-motor/duralast-relay-radiator-cooling-fan-motor/plymouth/voyager-2wd/1996/6-cylinders-3-3-0l-mfi/412240_0_0
Sep 22, 2015 | 1996 Plymouth Voyager
Where is the fuse for motor fan in uplander 2006?
there is 2 fuses that you have to check
one will be in the big fuse assembly in the engine bay, the other probably in the fuse assembly in the cab
If they prove ok then it is possible that the coolant temperature SENSOR is faulty and needs replacing
don't confuse it with the temperature sender which operates the temp gauge.
Aug 10, 2015 | 2006 Chevrolet Uplander
Cooling fan inop 1995 mustang gt 5.o
you can check the cooling fan by disconnecting the plug at the motor and run jumper wires from the battery directly to the fan motor it should run if its working if it doesn`t run then the cooling fan motor needs replacing. if it does run then check the plug for a bad connection. other things can cause this like the cooling fan relay, the coolant sensor that sends a signal for the computer to turn on the cooling fan by sending a signal to the relay.
Sep 08, 2014 | Cars & Trucks
Why Refrigerator does not cool?
condenser fan must run if it is to cool. does compressor run but not fan. fan need to be replaced ... will not cool until it is fixed.
Aug 26, 2014 | KitchenAid Refrigerators
My 1994 Toyota Previa LE overheats when I put on AC. It overheats while on idle.
cooling fan not running.check for faulty cooling fan relay or fuse.cooling fan fan should be running when you turn on AC.hotwire cooling fan make sure cooling fan motor okay.
Jul 10, 2013 | Cars & Trucks
Cooling fan does not run?
At the main fuse and relay box, check the 30A EGI INJ fuse. If OK, the main relay closes to apply power to the cooling fan relay. Next, check the 30A FAN 1 and FAN 2 fuses.If OK, power is being applied to the fan control module. The PCM processes engine coolant temperature sensor input and sends a signal to the fan control module which, in turn, causes the cooling fan motor to operate. Fan failure could be caused by malfunction of the cooling fan relay, the fan control module, the engine coolant temperature sensor, the cooling fan motor itself, or the PCM
Oct 06, 2012 | 2005 Mazda MPV
Cooling fan not running as temp. heats up.
most time coolant temperature sensor faulty.but check cooling fan fuse and relay.then hot wire the cooling fan if fan runs.problem in the fan wiring or pcm.if every thing else okay.if cooling fan dont run when hot wired the cooling fan need replacing fan motor has internal open winding circuit.
Apr 15, 2011 | 1995 Buick Skylark
How do i check the cooling fan my car is over heating
HOT WIRE COOLING FAN USING JUMPER WIRES TO BATTERY.IF FAN DONT RUN WHEN HOT WIRED FAN MOTOR BAD NEED REPLACING. IF FAN RUN WHEN HOT WIRED. CHECK COOLING FAN FUSE AND RELAY.IF ALL IS GOOD.YOUR ENGINE COOLANT TEMPERATURE SENSOR NOT WORKING.IT CONTROL COOLING FAN AT SET TEMPERATURE IF SENSOR OPEN OR FAULTY THE COOLING FAN WONT TURN ON.CHECK COOLING FAN WIRES FOR DAMAGE.IF ALL STILL CHECK OUT GOOD HAVE VECHICLE SCANNED FOR PCM FAULT.IF IT FAILS NO COOLING FAN WONT TURN ON.
Dec 13, 2010 | Hyundai Elantra Cars & Trucks
Cooling fan stopped running
check fuse and relay.if all is good.hot wire cooling fan using jumper wires to battery.if fan dont run replace the fan.if fan does run you have a open wire or bad connection at cooling fan electrical connector.
Nov 22, 2009 | 1999 Jeep Grand Cherokee
LG GC-051SS Compact Refrigerator Logo
156 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
