Question about Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
I can't delete write protected files or folders. How to delete it please any solution.
2 Suggested Answers
crazyZ2
  • 19 Answers
SOURCE: write protection of pendrive
This seems to be the problem of most of us these days and some of our readers who wanted to know the methods how they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without this switch but not to worry. Just download this helpful software from here and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“. Dont worry, partitioning a pen drive means allocating it its File System and Cluster Size that was lost after the Low Level Format.
For that:
  1. Run diskmgmt.msc in Run.
  2. In the disk management window, select the pen drive, right click on it and click on Format.
  3. Now choose the File System and Allocation Unit Size and do not check the boxes below.
partition_the_pen_drive.jpg Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
010101 G.I.G hacker 010101
www.gighacker.blogspot.com
Posted on Feb 12, 2010
Windows Explorer makes folders that are not needed? How do I delete them when they say write-protected?
Chances are your Windows Explorer is set to show hidden files. Some are write protected because they're crucial to your OS's functionality.
Hope this helps!
Sep 15, 2014 | Microsoft Windows XP Home Edition
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
I transferred a couple mp3's to my NWZ-E344 that were write-protected (marked read-only). Now I can't delete them from the player. I tried several ways, WMP, opening from My Computer, and...
"Write Protection" is a definate problem, but may be solvable (short of reformating) by checking the original files which, most likely, came from a CD copy. To see the attributes, right click on the icon and go down to select properties. There you will find "read only" highlighted for both the album folder and its sub files or songs. At this point the trick of avoiding "write protection" is to select the "read" attribute to unselect "read". Then select "Apply" and a window pops up showing boxes, one of which will say apply to folders, sub-folders or files, etc. Click on that box, then click on "OK". You will notice that the folder "read" attribute will remain highlighted, but that the subfolders' attributes do not!! (This is for Windows XP) At this point proceed to copy this folder OVER the same folder. You will be asked if you want to overwrite the existing folder with the same name. YES, please. The files will be replaced with identical file data, except the "read" attribute will be blank or unhighlighted, and NOW you can delete the folder.
Sep 18, 2017 | Sony Walkman NWZ-B103F MP3 Player
I cant delete some video clips from my pc, every time i tried to delete it, a message appeared.. saying " Make sure the disk is not full or write-protected and the file is not currenty in use" ...
Seems like files and/or folder is write protected ( in Read Only Format ).
Right click on the folder and click on properties. Check if there is a check mark on Read Only or any such other check mark. If so, remove those check marks and then open the folder and try to delete.
If this does not work, Check with the file you wanna delete in same way.
If it still does not work, you most likely do not have permission to delete files on your PC profile that you login with. You either need to be administrator of the PC with admin rights or the person who has the admin profile should give you full rights on your profile.
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 14, 2011 | Computers & Internet
Hi, while starting my pc a message displayed that cannot find the script file c/windows/system 32/rahul's virus protection vbe
Let it be a lesson how not to run computer without protection, your computer is infected with rahul malware/virus...
Please follow this advice:
1. switch computer off
2. boot computer in safe mode (tapping f8 during boot up will get you there) as an administrator with network connection
3. go to this site and run they free online scanner:
http://www.eset.com/online-scanner
4. still in safe mode download and install ccleaner
5. run ccleaner, as last run registry ccleaner
6. reboot computer as "normal"
7. do yourself a favour and buy nod32 antivirus, install it and allow it to protect you...
8. download from Microsoft they free Malicious Software Removal Tool and run it as well
If above did not remove all traces of rahul, please follow that advice for manual removal:
1. click on any folder on the desktop
2. select any folder and click "tools" or "properties", you did not stated which windows you run, cannot provide exact instructions
3. select "folder options"
4 select "view"
5. select "hidden files and folders"
6. tick "show hidden files and folders"
7. remove tick from "hide extensions of known file types"
8. remove tick from "hide protected operating system files"
9. search for any file with "*rahul*.*" in title (that includes file mentioned by you in the problem question)
10. delete these files, if files "refuse" deletion, click on they properties, one by one, unselect tick from "read only", click "apply" and then delete
11. remove file "autorun.inf"
12. re-boot with full shut down in safe mode (step 1 and 2 of first part) and run ccleaner again including as last registry ccleaner
Hope this will solve your problem, and buy this antivirus... If problem still persist, do not hesitate to call me back on this thread, if succesfull please leave note.
Aug 16, 2010 | Computers & Internet
How do I fix Error 8E5E05F6
Try the following:
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
Delete images tagged to mp3
you can go to folder options and select view menu >>> show hidden files and folders + remove tick mark from hide protected operating system files and u can go to the folder where your mp3 files are. and u will wind some pics. Delate them. If it dosen't work word please remind me ok.
Aug 31, 2008 | Apple iPod MA446LL/A MP3 Player
How to remove write protect on my usb flash drive
There is a software on internet, it is FREE of charge, it is called unlocker, it's a simple installation that lets you delete, rename, move any file/folder, just right-click the desired file/folder, go to"Unlocker" the image is a wand, and select the option you want.. works for me. good luck. hope this helps
Jun 02, 2008 | Creative Labs Zen Digital Media Player
Electronics - Others Logo
471 people viewed this question
Top Transcend Electronics - Others Experts
Joe Goldman
Joe Goldman
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
