I have an Grundig GHC 1000 home theatre which appears to have activated the circuit protection. Hence no sould. How do I de-activate
  • 4234 Answers
SOURCE: Onkyo TX-NR905 Protection Circuit Activated
The problem is not with the inputs. This unit is in protect because a problem has been detected in the output section. Try disconnecting the speaker wires and turning it on. If the unit remains on, there is a short in one of the speaker wires. If the unit still shuts down, there is an internal problem that will require repair. It sounds like this is a new piece. If so, it should be covered under warranty.
Keep us posted,
Dan
Posted on Jul 28, 2008
  • 336 Answers
SOURCE: The amp protection circuit was actived - what should we do?
Remove all speaker wires from the receiver and turn it on.
If it still goes into protect, I'll bet the house that one of the channels is shorted out and it needs repair. This is a job for a pro.
If it doesn't go into protect, check for a short in the speaker wire or for a bad speaker.
Posted on Jan 29, 2009
marsrover
  • 682 Answers
SOURCE: Amp protection circuit has been
1-check your input cables from connected equipments(cd player or dvd p
layer or any other media source).
2-adjust your input signal level(from-10 db to 0 db).
3-amplifier power must be bigger than total power of all loudspeaker with 20%----(if total power of loudspeaker is 8 watt amplifier must be 10 watt.
Posted on Nov 28, 2009
SOURCE: protection circuit activated
Audio amplifiers IC's damaged need to be replaced
Posted on Apr 12, 2010
TOLhamRadio
  • 509 Answers
SOURCE: Protect circuit activated........where to look for
Typically a shorted speaker output. CHeck where your speaker wires are and see if there's just one wisker of wire touching the adjacent terminal. Check the back of the amp (easier said than done) and then check the back of the speakers themselves. Second most common issue is overheating. People leave an LP covering the ventilation openings on top of the amp and wonder why it overheats, so make sure you have air ventilation. Speaker wiring, then ventilation. Unplug unit, plug back in again, and power on and see if your problem goes away; if not, come back and we'll see what else we can try for you - okay?
Posted on Aug 13, 2010
I have a pfaff coverlock 4862 serger and the power which is triggered by the folding door in the front of it keeps shutting off. What sould I check?
There is a safety switch activated by the front door that apparently is not being fully de-activated. Perhaps the door is not straight or not completely closing.
Jun 04, 2017 | PfaFF Sewing Machines
Interior lights
This is both a courtesy and safety issue on many high end vehicles. The light from the interior lights can cast enough light to get to front door and possibly show dangers in your path. And after first getting into you car and starting it, you can check the back seat for any unwanted hitchhikers. As for the 10 minute timer, I don't know if this can be adjusted. A Chiltons/Haynes repair manual for you car may have that answer, or, the Buick dealership shop foreman. Best of luck.
May 31, 2015 | 1998 Buick Park Avenue
Denon s101 fault
From the Manual:
PROTECT indicator
This indicator lights red when the system
cable is not properly connected or the
protection circuit in the subwoofer (DSW-
S101) is activated
Nov 09, 2013 | Denon Audio Players & Recorders
Can I connect my digital receiver to my grundig ghc 1000 home theater? And how I can make the connection?
That depends on the make and model of the radio, and the available inputs on the GHC1000. Does your radio have a line output socket? If not, you can generally use the headphone socket to source a signal. Then all you'll need is a cable with a 3.5mm stereo plug on one end and two x RCA plugs at the other - easily available at low cost from an electronics store. The RCA plugs go to a free line input on the Grundig amplifier and the 3.5 mm plug goes into the radio's headphone socket. HOWEVER some radios require a DC return path to detect that there is something plugged into the socket. You Grundig cannot provide this, and if your radio needs it, this method will not work. So hopefully your radio will not need it.....
By the way, you will have to experiment with the volume setting on the radio if you decide to try connecting it this way and find that it does work. Set too low there will be insufficient audio to run the Home Theater at reasonable volume, too high and you'll get distorted sound. Trial and error is the way to go, but start with the Grundig's volume control set to a low level and the radio's volume control set about half way - to protect your speakers from potential damage if you accidentally drive them too loud
Oct 08, 2013 | Audio Players & Recorders
Plse help i have a grundig model 3680 serial 341010a0087248 need code plz?
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Mar 18, 2013 | Car Audio & Video
I need the code for my Grundig WKC 5300, S/N GR1030T0219435.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Jul 02, 2012 | Car Audio & Video
Hello, I have an old Pioneer VSA-1000 home theatre
I have a Pioneer VSA-1000 with what sounds like the exact same problem. It is the world wide model with multi-voltage selectors.
I bought a schematic a couple years ago that I found at www.servicemanuals.net. Cost USD $21 at the time.
Mar 01, 2010 | Pioneer Audio Players & Recorders
Amp protection circuit has been activated
sometimes the protection circuit will enable because of a bad speaker i would suggest taking the load off of it by removing the speaker wires and turning it back on. if it stays on take an ohm meter and check the speakers should be between 2-4 ohms load.
May 01, 2009 | Onkyo A-9555 INTEGRATED DGTL AMPLIFIER...
Denon AVR3300 - Resetting activated Protection Circuit
Hi
Remove all speakers cables or wires and check all from behind the Receiver. if there are any loose terminals or any metal object in between the terminals.
though it might be a coincidence that you have a problem in the Receiver.
unplug the power cable from the wall socket and remove all cables.
after you remove the cables plug the power cable in the wall socket and try if you see the protection displayed , the receiver needs service.
Good Luck
Regards
Nov 02, 2017 | Denon AVR-3300 Receiver
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Apr 13, 2008 | Televison & Video
220 people viewed this question
 Grubhead
Grubhead
