Question about Maytag Neptune MDG5500AW Gas Dryer
The dryer runs but only cold air no heat. - Maytag Neptune MDG5500AW Gas Dryer
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
Dryer will not blow hot or cold air
what's the brand name and model number?i don't understand what you mean it won't blow hot or cold air?if you have the vent line off of the back and the dryer is running and you don't feel any air blowing out you could have a bad blower wheel,if you write back let me know if it's running and what it's doing.thanks
Feb 17, 2013 | Dryers
I have a ler4634eqo and it runs but it stopped heating up and drying the clothes. It still blows air just cold air.
check circuit breaker heat is on seperate circuit may run with one circuit then check continuity on element,then limit switches, then timer
Feb 11, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer (model lg5791xmw1) blows cold air. I switched out the igniter, dryer heated up and we put a load of laundry in. Checked in a half hour and dryer was running cold again. Thermal fuse?
no, cause thats a one shot deal, check your hi-limiy switch on the element case,they get weak from heat and can cause all kinds of (Under-Overheat) problems
Oct 15, 2009 | Dryers
My 970-c85092 dryer only runs cold air. I'd like
not likely a fuse. check the heating element for a break. the thermal fuse will shut the dryer down completley. could be you need an upgraded thermostat kit for the heater assy.
Oct 04, 2009 | Dryers
Dryer run but dosen't heat strong cool air flow from rear of machine
heating element needs to be replaced, its just blowing cold air and probably the vent hose is loose
Sep 11, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Dryer blowing cold air only
Check your heat sensors, one or more must be OPEN.
Mar 26, 2009 | Kenmore 84052 Dryer
Will not dry clothes,blows cold air.
need brand.most dryers have thermal fuse that protect the element from going bad.I would first check your breaker and make sure it isnt tripped.a dryer will run but not heat if breaker is tripped.
Mar 10, 2009 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
43 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
