Question about Video Game Consoles & Games
What type of television is required to set up a wii
    Genius:
  • 1,175 Answers
Any TV that has either composite video in ( Yellow jack and red/white jack) or one that has HDMII connections
Posted on Oct 12, 2010
We connected the wii u to my sons tv but nothing appears on the screen and it only appears on the game pad
Make sure the tv is in the correct input, as in, hdmi 1 or 2. I think the set up process requires you to use the pad first.
Jan 04, 2014 | Nintendo Wii U
Tip
How to fix Wii Error Code 52130
To solve this error, try to manually setup the Wii console using your network IP settings.
To do a manual setup of the Wii console using your network IP settings :
  • On a PC, click Start > Run > type CMD and press Enter > type IPCONFIG/ALL and press Enter. On Windows Vista, click Start > type CMD in the Start Search box > click on CMD icon > type IPCONFIG/ALL and press Enter.
  • Locate IP settings and use them to manually set the Wii console.
  • Restart your wireless router by unpluging the power from the wall and plugging it back in. Try to connect the Wii console to the internet.
You may also try to disable the wireless router security or firewall. Try again to connect the Wii console to the internet.
on Aug 26, 2010 | Nintendo Wii Console
I can't connect my wii to my wifi
Using your computers wireless manager, or an ethernet cable if applicable, connect to the Cradlepoint router.
Open your browser and enter 192.168.0.1 in the address bar of your browser.
Entering the last 6 characters of the MAC address will get you into the Admin level of the router.
Go to the Tools tab and select 'User Login' from the menu on the left of the screen.
Find 'Require User Login' and uncheck the box. (Earlier Firmware versions will find this box under the Basic tab, click 'wireless'.
Click 'Save Settings' at the top of the page, leave this page open as we will return to it later.
Turn on the power to your Wii
Now search for an access point on the Wii consoles main menu, just click on the Wii button in the lower left hand corner.
Now click on Wii Settings
Clicking on the blue arrow on the right side will take you to a second settings screen.
Select Internet, select Connection Settings, select None, select Wireless Connection, then 'Search for an Access Point'.
The Wii should search for wireless routers within range and display a list, choose your router from the list and click OK.
If you previously selected a security level for the router there will be a padlock icon next to the name and you must enter the same settings in the Wii that you entered into the Cradlepoint.
Click 'Save' and then click 'OK' but DO NOT choose OK to start a connection test!
Back on your computer, click on the Advanced tab on top and select Gaming from the menu on the left of the screen.
Under 'ADD GAME RULE' be certain that the 'Enable:' box is checked, and in the box next to 'Name:' type in "Nintendo Wii",
Next to 'TCP Ports to open:' type 80, 443, 28910, 29900, 29901, 29920 (exactly with commas)
Next to 'UDP ports to open:' type 1-65535 (exactly again). Click 'Save'
Return to your Wii and click on 'Choose OK to start a connection test'.
If you are still having difficulties (Wifi only), Nintendo tech support has recommended changing the channel of the router to either 1 or 11
Apr 20, 2013 | Cradlepoint MBR900 Mobile Broadband N...
I set up my wii last week so i could use netflix on it. lastnight it stoped working an now when you try to use it it says error code 50300. what can i do to fix it
The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered. It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings. Click here for help. While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click here for help. If the problem persists, try our general troubleshooting for tips.
Jul 15, 2011 | Nintendo Video Game Consoles & Games
Cannnot connect to the internet error 50300 0n tv screen?
Hi.
It appears that your Wii console's Internet connection may be affected by wireless interference.
Try the following:
1) The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
2) It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
3) While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option. Click on the link below for help
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
If the problem persists then please click on the below link to troubleshoot any problems.
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Good luck.
Jun 09, 2011 | Nintendo Wii Console
Help, Im trying connectmy wii to the wireless internet and I keep getting a error code number 50300
Error Code: 50300 The Wii console's internet connection settings are not correct. This could include your network name (SSID), WEP or WPA keys, or any manual settings you may have entered.
  • It's possible something has changed since you last connected online with your Wii console. Try setting up a new connection file, using your router's settings.
  • While "Search for an Access Point" is the easiest and recommended connection type, your network may require you to use the "Manual Setup" option.
  • If you are still getting this error code, please call 1-800-255-3700 for further assistance.
May 21, 2011 | Nintendo Video Game Consoles & Games
Does the Microsoft LifeChat LX-2000 Headset work on the ps3
Yes, every head set is capable of receiving audio sounds only require the type of connectivty. For example, the headset may require pin connection so long as the device PS3 has audio outlet. Also, wireless headsets that communicate by wii fii would require powering on the wireless signal acquirer. Thereafter each device should ascertain signal transfer. usually, the PS3 would require powering on any wii fii accessibilty buttons to search an acquire wireless signals in this situation audio.
Jan 12, 2011 | Microsoft LIFECHAT LX-2000 RETAIL Headset
Wii will not connect to internet
here is a trouble shooting guide. follow the steps and if you require further assistance please let me know. This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting: Are you using WEP or WPA security on your router? Log into the router using the default IP (consult your router's manual for assistance) Locate the "wireless security" section of your router settings and find the WEP or WPA key. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters). If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot. If you are using WPA, the Wii console is compatible with the following types: WPA - PSK (TKIP) WPA - PSK (AES) WPA2 - PSK (AES)
If your WEP or WPA key is correct, then the problem might be related to MAC address filtering: From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model). If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings). If the Mac address filter was disabled, then continue troubleshooting.
Check Nintendo's router info for special notes, if available, for your router. Click here to go to our Wireless Router lookup page. Use the drop-down box to select, if available, your router manufacturer. Click on your router's model number, if available. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings: On your PC, click "Start" and then "Run." Type "CMD" into the field that appears to open a new window. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response. if you require further assistance please let me know and i will be glad to assist you. -Midwest-tek
Jun 26, 2010 | Nintendo Wii Console
Hooking up Wii with monster cable kit to Onkyo SR875 and Mits 73" HD TV. I cannot get sound through receiver. What am I doing wrong? I can hear the sound through the WiiMote, but no sound through my...
If the Monster cable kit is in fact compatible with the Wii, continue with the following instructions. Otherwise use the Wii connectors.
This is only one connection method for your equipment but the easiest and requires the use of only one additional cable.
Connect the audio and video cables from the Wii directly to your television. Then connect an audio cable from the "variable audio out" or "audio out" from the television to the audio input of your choice on the receiver. Then select that input on the receiver. Then select the input on your TV that you plugged the Wii into. Enjoy.
Jan 13, 2010 | Onkyo TX-SR875 Receiver
Wii cant play the game
Hi . i have had this sorta problem when i play the resident evil game. I find that if you go to your menu on your startup screen and change the screen resolution it should work. some games require certain television res to allow play.
Feb 28, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
