Question about Belling BE811 Bottom Freezer Refrigerator
Belling Be111 Fridge/Freeze the freezer part is leaking??
jgwhomeequip
  • 1902 Answers
SOURCE: bosch fridge KSU 44 leaking water from bottom of fridge
Check the hose or the drain hole in the back of the freezer make sure hose is connect and the drain hole is not plugged
Posted on Feb 07, 2009
  • 8 Answers
SOURCE: 6 yr old side by side inglis fridge/freezer. water
can be from an obstruction (i.e. food or debris) or incomplete defrost. water forms around the drain during defrost cycle and ices up when cooling cycle comes on. defrost the drain and try installing a heat probe part#819043 made by whirlpool.its a metal rod that wraps around the heater and goes into the drain opening to prevent the drain from icing up. hope this helps.
Posted on Oct 22, 2009
SOURCE: Belling Bi60 Integrated fridge freezer (fridge) not working
I also have probs with Belling Bi 60 less than 3 yrs old...already had
enginneer out & paid......now fridge aint cooling showing H
its frost free and this may be too sensitive ??
tried unplugging no Go
wont buy Belling again
Posted on May 19, 2010
  • 22 Answers
SOURCE: bosch fridge leaking water
ok seems here that u have a defrost problem or a buggered evap fan motor ie is there breeze flowing from the cover at the back of the freezer if yes than this fridge has not got a manual defrost control it has an electronic timer built into the main pc board witch means that it could be the defrost element itself or the main pc board is gone looks like u will need to consult a professional to resolve this problem taking into account that there is at least some water dripping into the drip trey at the rear of the fridge at the bottom on top of the compressor if not than it could be a blocked drain
Posted on Sep 10, 2010
imufo2
  • 3773 Answers
SOURCE: what temp should belling fridge freezer be set at.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 30, 2011
Hi I have a Belling BCF10 chest freezer. The power light is not lighting but the freezer is still freezing, what is wrong? Also when should one use the fast freeze switch? Thanks in advance
If the freezer is working properly then the circuit that feeds the power to the power light is not working or the light itself is burned out. Either one or the other.
Sep 17, 2016 | Belling Freezers
I AM LOOKING TO PRICE A BELLING BUILT IN FRIDGE FREEZER
Michael, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cooling
Belling Integrated 70 30 Fridge Freezer
Buy Belling BIFF233 Integrated 70 30 Frost Free Fridge Freezer from...
http://www.powercity.ie/?par=45-25-BFF233
Mar 12, 2016 | Belling Refrigerators
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
Fridge freeze lg grb 207 keeps leaking
check your defrost drain hose and inspect defrost pan for cracks /holes
Sep 19, 2009 | LG Refrigerators
Bosch fridge KSU 44 leaking water from bottom of fridge
Feb 07, 2009 | Bosch KSU49630 Top Freezer Refrigerator
Dec 15, 2008 | Refrigerators
Belling be810
Hi the problem is with a clogged drain hose that's why all the water. to unclog turn off fridge. pull away from the wall . remove back panel. clean all vents . locate drain tube, by the drain tray. clean out the drain . thanks the appliance doc
Oct 06, 2008 | Belling Freezers
Belling intergrated Fridge Freezer
On integrated appliances the power supply is invaribly behind the unit. However there is normally an isolator to the side of the unit or in a side cupboard. Hope this helps.
Aug 06, 2007 | Belling BE811 Bottom Freezer Refrigerator
Belling BE811 Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Belling Refrigerators Experts
Andrew Taylor
Andrew Taylor
L Pfaff
L Pfaff
Nater13
Are you a Belling Refrigerator Expert? Answer questions, earn points and help others
