Question about HP LaserJet 4350 Printer
Error 60.02 on hp laserjet 4350 - HP LaserJet 4350 Printer
SOURCE: hp laserjet 4350 printing slow down
Look on the left side of the tray. There should be 3 white fingers that stick out. Make sure they aren't broken or out of place. Also slide the paper size lever and make sure they work properly. There is also a custom and standard switch. Try to print out of the MP tray(fold down tray). If it prints normal speed, you probably have a problem with the tray.
Posted on Nov 16, 2006
xcanox
  • 32 Answers
SOURCE: 49 4C02 error
Well I was having the same problem. I cleaned out the queue by canceling the job that it was having the problem with. Turns out the data being sent to the printer was corrupt in this case.
Posted on May 30, 2008
wheatlandsvc
  • 1110 Answers
SOURCE: HP Laser jet 4350 dtn printer gets 59.40 error. I
Print Cartridge Motor Error.
Try removing then re-installing the cartridge. If that does not work then you will need to try a different toner cartridge as the toner cartridge is "locked up". These are the most common solutions. If none of these work then you have a cartridge drive problem and will need to contact a service center.
Posted on Jan 05, 2010
Testimonial: "It worked. Thanks. I' just FIXYA again"
iron_luiggi
  • 91 Answers
SOURCE: I have a 49.5001 service error on a HP 4350
X PRINTER ERROR A firmware error occurred 1. Press CANCEL JOB to clear the print job from the printer memory. 2. Turn the printer off, and then turn the printer on. 3. Try printing a job from a different software application. If the job prints, go back to the first application and try printing a different file. (If the message only appears with a certain software application or print job, contact the software vendor for assistance.) 4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or printer. 5. Turn the printer off. 6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in the lowest DIMM slot.) 7. Remove all EIO devices from the printer. 8. Turn the printer on. 9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each device. 10. Replace a DIMM or EIO device if you determine that it causes the error. 11. Remember to reconnect all cables that connect the printer to the network or computer. 12. If the error persists, replace the firmware DIMM. 13. Replace the formatter.
This error is usually caused by a bad formatter board
Posted on Apr 05, 2010
seeker5211
  • 1089 Answers
SOURCE: LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
Posted on Jun 13, 2010
Error 50.40
50.4 is a problem with the fuser, likely a bad heating element.
Sep 09, 2014 | HP LaserJet 4350 Printer
51.10 error
Thank you for contacting FixYa. I have been working on some archieved inquiries that may have gone unanswered. Your issue is a beam detect error with your laser scanner.
HP LASER PRINTERS 4200, 4300, 4250, 4350 ERROR 51.XX
1. Printer has a beam detect error
2. Replace the cable ***'y from scanner to D.C. controller
3. Replace the scanner ***'y
4. Replace the D.C. controller.
Aug 25, 2011 | HP LaserJet 4350 Printer
My printer hp laserjet 4350 shows error 49,what could be the cause
Most times a "49" error indicares the need for a firmware upgrade.
If the machine is networked, disconnect the network cable and power the printer off, wait 2 minutes and power it back up. It should reset the error.
BEFORE reattaching the network cable delete the job in the printer queue that caused the error ( Most likely a PDF file).
Go here:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=412171&prodTypeId=18972&prodSeriesId=412160&swLang=8&taskId=135&swEnvOID=228#290
and download and install the latest firmware
A workaround is to print the PDF as an image
May 20, 2011 | HP LaserJet 4350 Printer
I am getting 60.02 error on the display screen. We are using hp LaserJet 4350.
Tray 2 lifter motor is bad. I've seen this quite a bit, it's usually the soldered wire breaks off. To replace you will need to remove the following:
  • Rear accessory cover.
  • Top cover.
  • Right-side cover.
  • Formatter cover.
  • Formatter.
  • Paper-pickup drive assembly
I've attached a picture to show what it looks like:tballone_1.png
Mar 01, 2011 | HP LaserJet 4350 Printer
Marca error 60,02
60.2
The tray 2 lifter-motor is not functioning.
1 Turn the printer off and then on.
2 If the error persists, turn the printer off.
3 Verify that the tray 2 lifter wire-harness
is full seated in its connector on the
dc controller PCA (location J93).
4 Replace the tray 2 lifter-driver
assembly. See Tray 2 lifter-drive
assembly.
5 Replace the dc controller PCA. See
Dc controller PCA.
Aug 09, 2010 | HP LaserJet 4250dtn Printer
LaserJet 4350 Printer: 49.2f02 service error on hp 4100 printer...
Turn the printer off for a few minutes and then back on. If that does not fix the problem, try to have the print queue cleared and tray again. Most of the time it's a PDF file that causes this problem. If that does not fix it, it may need a new Jetdirect card.
May 16, 2010 | HP LaserJet 4350 Printer
49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Jan 21, 2009 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
1,496 people viewed this question
Seeker5211
Seeker5211
