Question about Brother DCP-110C All-In-One InkJet Printer
Say's empty HI have replaced all the colors in the printer on a dcp110c brother and it say's to replace the black to which i have taken in and out several times and it say's the rest of the colors are near empty. no mater what i try to do it just beeps at me
  • 2 more comments
  • saxkarak Jun 01, 2008
    machine error 46
  • Anonymous Jun 14, 2008
    I have this problem too.
  • m4929 Jun 29, 2008
    My printer indicated that my yellow cartridge was empty and that the magenta was almost empty. When I replaced those those colors, it then indicated that the cyan should be replaced. When I removed the cartridges, all three had slightly more than .25 of an inch in depth of ink. The printer is once again printing properly, but I feel that this is a waste of ink. In the past, the cartridges were truly empty when the message appeared on the screen concerning their content.
  • kei16_brux Jul 25, 2008
    I also replaced the cartridges but still it says its empty.. to open the scanner cover and replace the ink.. I did it several times already but it still can't read the new refilled cartridges..
  • Brother Master
  • 4,338 Answers
If you still need help:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.html?reg=us&c=us&lang=en&prod=dcp110c_us
Why does my machine's LCD show "NO CARTRIDGE" even though I have already installed all the ink cartridges?
Description:
If the message "NO CARTRIDGE" remains on the LCD after you have installed the ink cartridges, then one or more of the cartridges may not be properly installed. Verify that the cartridges are installed correctly by following these steps:
Note
    Cartridges that have already been installed are no longer vacuum-sealed, so it is very important that these cartridges remain upright. If a cartridge is removed from the machine and placed on its side, air may be introduced into the ink supply tubes. As a result, repeated cleaning will likely be required before normal print quality is restored.
  1. Unplug the machine from the AC power outlet, wait approximately 10 seconds and then plug it back in.
    If the date and time appear on the display, the issue is resolved. If the display continues to show NO CARTRIDGE, continues to Step 2.
  2. Open the scanner cover by lifting it from the right-hand side until it locks securely into the open position.
  3. Remove the black ink cartridge by pulling the white plastic hook (locked over the edge of the ink cartridge) toward you, then lifting the cartridge out.
  4. The LCD should prompt you to install the black ink cartridge.
  5. Reinstall the black cartridge. Press down FIRMLY on the top of the cartridge until it is fully seated. Push the white plastic hook towards the cartridge to verify it is fully latched over the cartridge's top edge. Repeat STEPS 2 - 4 to verify each that of the color cartridges (magenta, cyan and yellow) is installed properly, then continue to STEP.
  6. Close the scanner cover. The unit should begin cleaning automatically.
Please remember to rate all Techs who assist you for free :) Joe
Posted on Oct 04, 2008
Printer keeps telling me that the yellow cart is empty and I have put a new one in
Are you positive it says the yellow cart is empty? Because that brother printer is designed to say that a cartridge is empty whenever ANY of the color cartridges are empty. Usually it doesn't tell you which one is really empty either. So even if you replaced the yellow cartridge and say, the black cartridge is empty, it still won't let you print until you replace that empty black cartridge, nor will you know which of the cartridges is empty unless you pull them out of the printer and manually check the ink levels.
Its pretty much a guessing game with those old brother ink printers.
Hope this helps :)
May 03, 2010 | Brother MFC-5440CN All-In-One InkJet...
Emptied out both black and color ink cartridges. Replaced black ink only. Printer is not printing. Getting flashing E and 5 on printer. Does this mean the printer will not function until I replace the...
You should maybe replace the color cartrige even if it`s empty just so the printer recognize that it have both slots taken.Then try to print out in black/white.
Feb 09, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer will not print dut to other color cartige. being empty.
The color cartridges print text that appears black by mixing the three primary colors (cyan, magenta, and yellow) to make composite black. To achieve a realistic black, large quantities of colored ink are used. Because black cartridges use much less ink to create a similar shade of black, they print more pages in black than the color cartridge.
If the color cartridges on the printer are next to empty, you will not be able to get perfect prints at all.
Please have the cartridges replaced to do the printing jobs again.
Sep 10, 2009 | Brother Multi-Function Center MFC-240C...
Wont copy in black because color cartridges are empty
I'm sure you're using the Blue button to make the copy as it should do B/W copies only.
Double-check that black cartridge is not empty.
If the printer was connected to computer then we could have used diagnostics software.
So we start with a workaround.
Check if its display menu has any option of Ink cartridge level reset or something like that. If it has then do the reset.
If there is no such Menu option, the while the printer is On, open the compartment of printer cartridges and take out the 4 cartridges
and put it back.
Does any option in display Menu comes asking if cartridges are replaced? answer yes if it asks.
Now try to do a copy.
Hope this helps.
If it doesn't work then a question, how many days before the printer was last used?
May 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Unable to init appear on the lcd screen. after i replace the black ink. what should i do?
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000002258&Sympt=How+do+I+clear+the+message+Please+Wait+%E2%80%93+Unable+to+Initialize+from+my+Brother+machine%E2%80%99s+display%3f+(pls%2c+init)&Model=22&ProductGroup=5&Keyword=unable%20to%20init&ProductID=DCP110C
Mar 28, 2009 | Brother DCP 115C All-In-One InkJet Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
I have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Oct 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Not printing
i have a brother mfc 5440cn printer,error message says out of black ink,i replaced it,still says out of ink,i opened and checked micro switch,then bypassed micro switch,still reads out of black ink and wont go any further than that
Sep 29, 2008 | Brother MFC-5440CN All-In-One InkJet...
Color cartridge
The Brother machine will not print if the message "Toner Empty X" ( X =C for Cyan, M for Magenta, Y for Yellow and K for Black) is displayed on the LCD. The empty toner(s) must be replaced in order to continue printing. Incoming faxes will be stored in the memory until the toner(s) is replaced.
May 10, 2008 | Brother MFC-9420CN All-In-One Laser...
Brother DCP-110C All-In-One InkJet Printer Logo
286 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
