Question about Dell Dimension 8200 PC Desktop
Will not boot from power button
My Dell Dimension 8200 will power off and back on during a restart sequence, but it will not power back up if turned off. When I push the power button all that I get is a flashing amber light on the power button. I have discovered that if I remove the network card from its slot the pc will immediately power up just fine. Once up, I can reseat the card and it will continue to work. I have tried replacing the network card with a new one but the result is the same as with the old one. Any thoughts on what the problem might be?
  • 1 more comment
  • RCEvans Jun 04, 2008
    Dell's BIOS doesn't have an option to load default settings. Other than changing all entries to their default settings, is there a particular setting that I sould check? By the way, the BIOS wasn't altered prior the problem occuring.
    The problem has been occuring for many months and I wasn't able to identify a specific action that caused it. I did try restoring the computer back to an earlier configuration when I first noticed it but that didn't correct the problem. I typically leave the computer running so I only have to deal with the problem after a power failure. When it does occur, I have to open the case, unseat the network card, turn it on and then reseat the card with the computer on. Since reseating a card in a computer that is turned on is risky, I decided it was time to try and resolve the problem.
  • RCEvans Jun 24, 2008
    I just received and installed a new PSU today, a PCPC Silencer 410. Installation was a snap and the PC booted right up without a problem. Thanks to both of you for your suggestions!
    Problem Solver:
  • 8 Answers
Try going to Dell's support site and see if they have an updated version of your BIOS - if so, try 'flashing' your BIOS with the update and see if that solves the problem.
Posted on Jun 22, 2008
    Scholar:
  • 141 Answers
Hi RCEvans;
Remove your network card and boot your computer,tap F8 or the key in order to go into the bios settings and look for the option load default settings then save settings and try it. hope it helps
Posted on Jun 03, 2008
  • 1 more comment
  • james yu
    james yu Jun 04, 2008
    HI RCEvans;
    Im sorry, we don't have much dell in our area but anyways, have you tried tapping F8 and select last known good configuration?
    did you experience this problem before? can you give me some more information on what you did before this problem occured...
    thanks for the thanks :)
  • james yu
    james yu Jun 18, 2008
    Hi RCEvans;
    HOw is your computer? Im still wondering what might cause the problem, since you said you already change your network card with another one, is it of the same brand and model? have you tried placing your network card into another computer? you may want to try this option too because turning your pc ON 24/7 will hurt your cpu.
  • james yu
    james yu Jun 24, 2008
    Your welcome Mr Evans, i guess your PSU was not able to handle much of the power consumption. :) cheers on your new PSU
Power button on dell dimension 8200 is solid amber computer will not boot up what is it?
hi this looks like the hdd is not powering up...take the cover of the tower and disconnect the hdd power and see if the motherboard fires up on its owen......unplug the power to the motherboard and wait 5 mins plug it back in see what happens.......on the motherboard were you plug in the hdd led cables and power cable and the led cables and fined the one that has the pwr on it plug it in on its owen see if that helps you
Nov 12, 2010 | Dell Dimension 8200 PC Desktop
When i turn my dimension 8200 on it will not boot i keep getting the black screen with the safe mode option but no matter option i choose it aslways comes back to the black screen
if you have the windows xp disk, boot from it by pressing F12 upon turning on your computer. press 'R' to choose recovery console. you might be asked which windows installation you want to start, just press 1. when you see the console, enter the command 'fixboot' without the quotes. then type exit to restart your computer. hope it helps.
Mar 14, 2010 | Dell Dimension 8200 PC Desktop
My Dell Dimension 8200 PC keeps re booting itself once it gets to the home page. i cant even hit the start button cause it restarts itself that fast! please help
As soon as u see the black screen...hit F8 repeatedly to get it into Safe Mode.....then go to system restore and reboot/restore system back on a saved day. Then run your virus protection and scan for malware. This should get you back online. You may need a full system scan to locate the effected DLL's anmd killl off your intruder.
Jun 23, 2009 | Dell Dimension 8200 PC Desktop
Dell dimension 8200 flashing yeloow power button
Please find the complete error codes for dell 8200 and their fixes.
http://support.dell.com/support/edocs/systems/dim8200/codes.htm
This will help you to figure the type of error u are getting and its resolution.
Please feel free to rate this solution link.
Mar 19, 2009 | Dell Dimension 8200 PC Desktop
Dell Dimemsion 8200 Won't Boot - Beeping Sequence 5-2-2-1
Often simply disconnecting the power cable, holding power button for 15 seconds, release power button, plug back in will work
Otherwise remove CMOS battery and perform above operation
Hope it works
Feb 03, 2009 | Dell Dimension 8200 PC Desktop
DELL DImension does not boot
Try removing your RAM handling by the edges, clean the terminals with an eraser and reinsert firmly. Reboot your computer. Make sure you remove static charges from your body by placing your hands on a grounded object.
Sep 03, 2008 | Dell Dimension 8200 PC Desktop
Dimension 8200 will not turn on
Try a new power button. Also does the machine power light turn on at the front of the machine? if so check that the CPU is seated correctly as if it has come out of position then the machine doesn't boot. I would like to think power switch though.
Thanks J
Jan 17, 2008 | Dell Dimension 8200 PC Desktop
Dell Dimension 8200 PC Desktop Logo
142 people viewed this question
Alun Cox
