Question about LG Washing Machines
Dear All: I have been using LG WF-S 6617 from last three years. But It is mixing particles, which are deposited in its poach in the washed clothes now. Although the poach is regularly cleaned after each washing but the problem is persisting. Could you please suggest how to resolve this problem. Sincerely, Muhammad Shaban Rafi 426 Raza Block Allama Iqbal Town, Lahore, Pakistan
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
  • 62 Answers
SOURCE: oily substance
most common is lint build up. a good hot wash with a good bleach...check your manual for manufacturer's recomendation. There's various products available..bleach is the most in-expensive and works well. make sure its set on high water level...pause machine for 10-20mins...let me know how you get on
Posted on Jan 03, 2008
  • 4 Answers
SOURCE: lg wf-s6607tc
This is probably a lid cover open protection. Check to see if there is a magnet on the cover, positioned almost to centre (slightly to the right) at edge of the cover. There is some sort of plastic catch to house the magnet. If it is not there, place a magnet at the corresponding area on the washer where the plastic catch will touch when the lid cover close.
Posted on Sep 09, 2009
  • 291 Answers
SOURCE: LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Posted on Dec 14, 2009
  • 1244 Answers
SOURCE: Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Posted on Jan 13, 2010
My LG Fuzzy Logic WF T653A machine deposits little black unknown deposits on my clothes after every 2nd or 3rd wash, they look like little bits of black wet paper ?? some-one said to change the lint bags,...
Its called scrud.
Solution is to use a couple of quantum dishwasher tablets on a hot empty heavy wash.
Doing this on advice from an LG rep. May need to repeat it 3 times.
Brendan
Mar 24, 2013 | Washing Machines
I have a LG Fuzzy logic for a year and a half now, model WF-8071TTP top loader. it seems that after washing all my clothes are full of fluff. I have cleaned out the filter bag, and all little filters at...
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
Jan 17, 2011 | LG WFT1071TP Top Load Washer
Dec 14, 2009 | Washing Machines
Deposits on clothing
Be sure to seperate lint givers with lint taker, do not mix towels etc with clothes that are attracted to lint. Also be sure water levels are sufficient
Jan 13, 2009 | Kenmore 24032\24036 Top Load Washer
Oily substance
Jan 03, 2008 | LG WFT1071TP Top Load Washer
Sep 28, 2007 | Washing Machines
Oil and noise coming from my washing machine
i would think that the bearings have gone,spiin empty tub by hand and a rumbling noise will confirm also removing the rear cabinet will probably reveal a trail of rusty water down the outer tub.the answer is new shaft £40 and a bearing kit £22 your husband should be able to try it af as you say he is mechanically minded
Dec 19, 2006 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
