Question about GE Hotpoint Top-Freezer Refrigerator
Icemaker jack I removed the screws like you described. So the icemaker is off the freezer wall. I just have a question about the icemaker jack. I'm having a problem removing it. Is it something that should be pulled out or turned/screwed out? I wanted to ask be fore I kept working with it. BTW: Thanks so much for your quick responses! I've wanted this thing out for MONTHS!
    Genius:
  • 1,122 Answers
Most have a jack that snaps together they have tads on both sides you have to pull up and out to release,some plug right into the icemaker it's self,check to see witch one you have,if not sure of yourself unplug frig. and them do it,hope this helps somemore,mike
Posted on Jun 01, 2008
Plastic bag in icemaker
Unplug the icemaker from inside of freezer and remove the screws holding the icemaker to the wall. Pull it out and start removing plastic then reinstall. Do Not try to rotate the arms. this will strip the gears. Get tweezers if you have small pieces hung in there.
Aug 27, 2014 | Refrigerators
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
Icemaker is generating heat and melting items near it - Amana SR25F1L - how do I disconnect power to icemaker?
The icemaker has a plug on the back of it,by removing the screw from the bottom support bracket and then then 2 from the top of it the icemaker could be removed from the freezer wall so it could be unplugged.
GENE
Oct 08, 2011 | Amana Refrigerators
Maytag mfd2560hes how to replace defrost thermostat
The service manual 16025629 is here: (7.46 mb)
http://appliancedigest.com/index.php?/files/file/498-16025629-maytag-amana-bottom-mount-refrigerator-service-manual
You will have to register to download the manual.
Freezer Back Panel
NOTE: Freezer compartment should now be empty and
walls should be clear of anything that will
obstruct removal of back panel.
1. Loosen screws that mount icemaker to freezer
compartment walls.
2. Pull icemaker gently away from wall of compartment.
As you do so, work fill cup free of fill tube. Unplug
icemaker electrical connector and remove icemaker
from unit.
3. (Pull out Drawer only) Loosen and remove screws
that hold 2 basket glides in place at left and right
sides of compartment.
4. If unit has no icemaker pry with flatblade icemaker
connection cover. Remove cover.
5. Remove hex head screws that hold back panel and
remove panel.
6. Squeeze tabs on ice maker plug to release it from
back panel
Defrost Terminator (Thermostat)
1. Terminator is fastened to evaporator tubing with a
spring clip.
2. Snap terminator off tubing and cut wires to terminator.
3. Remove terminator from unit.
That is word for word.
See parts list diagram here:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170924&diagram_id=28480593#d28480593
This may help with screws but the defrost thermostat is item 32 and not shown on the diagram. Once you hav ethe access panel off loof fok the thermostat. It will have 2 wires and tough metal clip on it.
Thanks for choosing FixYa,
Kelly
Jul 20, 2011 | Maytag MFD2560HES Bottom Freezer French...
Ice maker leaking down in freezer along left side. I shut off the water and turned the icemaker to stop. How do I fix the leak?
Look for any tilt in the icemaker towards left, if so loosen both the screws, balance the icemaker.Then tighten the left hand screw first followed by right hand side
p.s the screws will be holding the ice maker with back wall, once you remove the ice bucket it will be visible
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
How to install Kenmore icemaker
2 screws on top of icemaker into wall (loosen almost all way) 1 screw bottom remove. pull IM up and off of 2 screws and disconnect wiring plug from IM (depress tab). reinstall in reverse.
Jun 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
A very unusual 'croaking' frog like noise from the back of the freezer compartment. It stops if the freezer door is opened and starts again once closed. The freezer light switch is involved: With the...
I have a Kenmore Elite Trio and the freezer was making a frog sound. I found the solution.
My model number is 596.75523400. The sound will stop when the freezer is opened. It will stop again when the freezer drawer is open and the light switch is pressed to turn off the light. The ice drawer was full but it had stopped making ice.
Here is the fix in less than 10 minutes using only a screwdriver.
  • Take out the two freezer baskets
  • Remove the freezer door from the two slide tracks.
  • Unplug the icemaker electric connection at the back wall. Depress the clips on the side of the plug and wiggle it loose.
  • There are 3 screws that attach the icemaker to the left freezer wall. Remove the lower screw and unscrew the top two about ½ way out.
  • Slide the icemaker up so the slots slip over the 2 screws.
  • Put the icemaker in the sink and run a bit of water on the frozen cubes until they fall out.
  • Take the screwdriver and check the water inlet hose/pipe for ice that obstructs the flow of water into the ice maker.
  • Re-mount using the 3 screws and plug in the electric connector. Make certain the water inlet tube is positioned thru the retaining hole before you remount the screws.
  • Replace freezer door and baskets.
Jun 05, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Replacing icemaker in GE GSH25JSTE side by side refrigerator.
generally its very easy. for your model it looks like the icemaker goes across the rear of the freezer section. if you will look on the left hand wall on the icemaker you will see a philips head screw remove this screw and pull the icemaker towards you and it will come out then unplug the wiring harness (this is probably the hardest part) there are 2 clips that keep the harness connected securley and you sometimes have to use a small blade screw driver to release them. onec icemaker is removed you have to remove the fill cup and the end stop off of the icemaker and reinstall on the new icemaker. one done just reinstall and turn it on. youre done!! BTW the new icemaker mostlikely will not have the green light the old one did so dont think youve got the wrong icemaker.. let me know if you need any further help Thanks Peyton
Mar 16, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Funny fridge noise, kenmore elite trio
Nov 01, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
I would like to remove the ice maker from my freezer.
REMOVE THE 2 MOUNTING SCREWS ABOVE THE ICE MAKE,REMOVE THE 1 SCREW UNDER THE ICE MAKER,DISCONNECT THE ICEMAKER JACK AND YOUR DONE,YOU NEED DO NOTHING ELSE,HOPE THIS HELPS,THANKS-MIKE
May 31, 2008 | GE Hotpoint Top-Freezer Refrigerator
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
