Question about Samsung WEP200 Headset
Thi is liu kang, i got a bluetooth headset i tried to activate and i can not make it work. Be cause on it required enter pin number. but i have lost my passkey. can you tell me what is the passkey for Samsung WEP200 Headset is?
    Guru:
  • 859 Answers
Hello Sir,
You must be frustrated by this problem. It should be easy to solve. All units transmitting on an open channel have a unique identifier. This is the Pass Key.
1.) Check under the transmitter and there should be some numbers. The one above the bar code is usually the passkey, but it could be another on the label so write them all down.
2.) Click on the Blue icon next to your time display in the System Tray.
3.) Double Click your bluetooth headset and when prompted for the passkey enter the first number you wrote down. If that does't work try the others. One of them is your passkey.
If you need further assistance comment back to me and I'll be glad to help.
Kind Regards,
Worldvet
Posted on Jun 01, 2008
  • Glenn Rogers
    Glenn Rogers Jun 01, 2008
    If this doesn't provide you a solution you may need to access features in your phone, if that's what you are using it for, and instruct the phone to connect to your bluetooth headset. The same thing applies the passkey should be on your earpiece as a label.
    Regards,
    Worldvet
  • Glenn Rogers
    Hello again,
    Here is the sequence:
    1. Ensure
      that the headset is off (see Turning
      the headset on/off
    2. Press
      and hold the Multi-Function button until the indicator light
      turns on in blue (approximately 8 seconds).
    3. Set
      your Bluetooth phone to discover the headset by following
      your phone’s guide. Typically, the steps involve going to
      a ‘Setup’, ‘Connect’, or ‘Bluetooth’ menu on your phone and
      then selecting the option to discover Bluetooth devices.
    4. Your
      phone will find the Samsung WEP200 headset and ask if you
      want to pair with it. Confirm this by pressing the Yes or
      OK key.
    5. Enter
      a passkey or PIN, 0000 (4 zeros), then press the Yes or OK
      key.
    Regards,
    Worldvet
    Genius:
  • 1,665 Answers
Another user tried 0000 just now and it worked immediately.
hold the button down for about fifteen seconds when you first switch on (you will hear the second beep)
I need the password
The default PIN to enter on your phone to pair the Samsung WEP200 is 0000.
Samsung has a Quick Start Guide for the WEP200 here: http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=2 . The User Manual is available at http://ars.samsung.com/customer/DownloadAnsTempl?AT_ID=70171&SEQ_NO=1 . If these links do not work, start at the Samsung WEP200 FAQ here: http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?SITE_ID=22&PG_ID=557&PROD_SUB_ID=627&PROD_ID=0&AT_ID=70171 .
I hope this helps.
Dec 24, 2011 | Eforcity Samsung Bluetooth Headset WEP200...
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
I need instructions on how to pair my WEP200 to my new cell phone please.
1 Turn your bluetooth headset off. If it is on, press and hold multi-function button(for about 4 seconds) until the LED blinks twice. 2 Prepare your bluetooth enabled phone to be ready to go to search mode. 3 Turn your bluetooth headset on in pairing mode. (Press and hold the multi-function button for almost 9 seconds. The LED will be steadily LIT.) 4 Activate the Search option in your phone. You should see Samsung WEP200 in your phone's screen. Choose that and press OK 5 The phone will ask for a passkey. Press 0000. Then press OK. Give it a few seconds, your phone and bluetooth headset will be paired.
Mar 21, 2011 | Samsung WEP200 Headset
What is the password for my samsung bluetooth wep200 headset so i can use it with my phone (blackberry bold 9700)?
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
Feb 15, 2011 | Samsung Bluetooth?® WEP200 Headset...
Earbud will not connect to lg env2
Pairing will create a unique and encrypted wireless link between two Bluetooth enabled devices, such as your Bluetooth phone and Bluetooth headset.
  1. Ensure that the headset is off (see Turning the headset on/off).
  2. Press and hold the Multi-Function button until the indicator light turns on in blue (approximately 8 seconds).
  3. Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to a 'Setup', 'Connect', or 'Bluetooth' menu on your phone and then selecting the option to discover Bluetooth devices.
  5. Your phone will find the Samsung WEP200 headset and ask if you want to pair with it. Confirm this by pressing the Yes or OK key.
  6. Enter a passkey or PIN, 0000 (4 zeros), then press the Yes or OK key.
wep200-5.jpg If pairing was successful, the indicator light will flash in blue 10 times rapidly before going to flashing every 3 seconds. If unsuccessful, the light remains on, and you will need to re-attempt pairing.
Dec 04, 2010 | Samsung WEP200 Headset
I got my samsung wep200 and I am unable to connect
You must put your headset in pairing mode, prior to making your PS3 search for new devices. To do it, start with your headset turned off. Then, press and hold the MFB (Multi-Function Buttons) for some 8 seconds, until the indicator light is steadily lit in blue. Now, make your PS3 search for new devices. After a little while the WEP200 should show on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros).
By the way, if your headset's user guide happens to be missing, feel free to download it from this location (if this link fails, please, let me know. I will upload it to some file sharing server for you).
Hope you are able to sort your problems out soon.
Regards, Carlos
Jul 23, 2010 | Samsung WEP200 Wireless Headset
When i enter the passcode it tell me passcode mismatch
Have you put your heaset in paring mode prior to trying to pair it with your phone (or computer, or any other bluetooth enabled device)? If not, start with it turned off. Then, press and hold the MFB (Multi-Function Button) for some 8 seconds, until the indicator light is steadily lit. It is in pairing mode now. Make your phone's bluetooth application search for new devices. After a while, the WEP200 should appear on-screen. Make it connect. If a paring code (or PIN, or passkey) is required, enter '0000' (four zeros).
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Regards, Carlos
Feb 15, 2010 | Samsung WEP200 Wireless Headset
Pairing a samsung wep200 headset to a samsung blackjack
blue tooth is a usb transmitter. so obvisously u got to get the 2 to the right frequency. look for a small button to press on the samsung...sounds like u need the manually. look online for it. good luck. Crazylarry
Jun 27, 2007 | Eforcity Samsung Bluetooth Headset WEP200...
Samsung WEP200 Headset Logo
152 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
