Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
We have just had a Rinnai Infinity 26 Enviro installed and when you are a metre away there is a smell of gas, when it is in use or not. Is this normal?
  • Rinnai Master
  • 2,557 Answers
No laeking when it is off needs fixing turn it off , need a gas fitter to fix leak asap
Posted on Oct 12, 2010
Why is my Rinnai Infinity 20 leaking?
Hole in heat exchanger caused by improper condensate drain?
Read installation manual, call service technician.
http://waterheatertimer.org/pdf/Rinnai-Tankless-Troubleshooting-Manual-2012.pdf
Replace with tank type heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Gene
Oct 01, 2014 | Rinnai Water Heaters
How to manually reignite rinnai infinity 26
what i would recommend is to turn power off to unit, turn water off, now open a hot tap inside. Go back to hw unit , turn power back on, now turn HW cold water tap to open. Now you should hear the unit start up.& click continuosly, this is the unit trying to lite. The unit has a flow sensor so as water passes threw it ,that tells unit when to lite. If you hear nothing & no water comming threw you strainer located above cold shut off tap is blocked, unscrew black knob & check. If you have flow & no HW check your gas, usally by losening gas union, there is also filter above this. Also plug another power tool into power point to check you have power
Feb 01, 2014 | Rinnai Digital Remote Water Heater Control...
I need a service manual for a Rinnai Infinity 26 continuous flow hotwater system - REU-VR2626WG-AK Can you help me? Linda
I left Rinnai only about a year ago at a levle of State Service Manager. I had been asking for service manual for for many, many months. Basically as far as I am aware there is not a service manual for the WG. If you google Rinnai Infinity 26 manual you can get a PDF from the Rinnai NZ sales site but his dates baack to 2003. Unfortunately there are major changes to some of the components but it might be better than nothing. Just don't use part numbers, and you might find bits to check that now have voltage and resistance differences. Send a message to Rinnai complaining, I encouraged people to do so even when I worked for them!
Aug 26, 2010 | Water Heaters
How far does a rennai 26 have to be from a air condition unit motor?
Distance from the flue to a mechanical air inlet for the Rinnai which has a fan assisted flue is one metre. I this is just the air con motor on a split system it is not really an inlet. However exhaust flue temperatures are hot so I would use the 1 metre rule in this case.
(Just for your reassurance i and I also used to teach gas fitting at the trade schools on occasions am a licensed gas fitter. Also worked for Rinnai for a few years)
Jul 23, 2010 | Heating & Cooling
Loud noises
did you size the gas line properly? sometimes if the gas pipe isn't sized properly it will cause some pretty loud wistling noises. also if you have something in the fan like bugs or lots of dust it will cause alot of problems with noises
Jul 24, 2009 | Rinnai Digital Remote Water Heater Control...
Where can I buy rinnai dynamo 15dyn gas heater 3 metre hose in sydney.
You Cant.
clause 2.4.6.1 from Nz/Oz gas code
Hose asemblies shall be:
(a) As short as practicable and not exceed 1.5m inside a building and 3m outside a building.
Jun 09, 2009 | Rinnai Vent Free Gas Heater/
Bad gas smell when heater is operating
I would call him back out. It sounds like a gas line is loose or the vent is not on properly
Jun 01, 2009 | Rinnai Vent Free Gas Heater/
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
284 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
