Question about Bosch Dishwashers
I have a Bosch SD1306B dishwasher and cannot see the "normal" salt compartment. Does this model not need salt? Is the logo that looks like an eyelash the symbol for the descaler fluid for keeping the glasses shiny? The light is on there. Sorry for the simple questions but I have no manual for the dishwasher and its my first Bosch. Many Thanks Neil Fraser
SOURCE: Water in salt reservoir
I've had the same dishwasher for 2 years now and always had water in the salt compartment. Don't know if this is normal but disn't seem to be a problem til now. Just fill with salt as if it was empty.
Posted on Jan 22, 2008
SOURCE: BOSCH DISHWASHER: ON/OFF BUTTON DOES NOT LIGHT THE DISPLAY, dishwasher doesn't work
loose wire in plug. fixed
Posted on Jul 16, 2008
SOURCE: Bosch HydroSensor Dishwasher (SGS5342GB/17) -
Hi Julie,
The sprayer arms may need replacing.
Posted on Aug 21, 2008
SOURCE: she47c0 bosch dishwasher won't stop
You're hosed.  This is likely a bad control board module that can run you in excess of $200.  Even if you're within Warranty, Bosch will gouge you for labor, as that is NOT covered by warranty.  Top that with abysmal customer service and you're in for a world of hurt.  Sorry, but it's time for a new dishwasher. :(
Posted on Oct 28, 2008
  • 409 Answers
SOURCE: Bosch Exxcel Dishwasher - manual please?
hi there,
no problem. the model # is usually located on the inside rim of the cabinet. open the door and locate the sticker itself. i will also need your e-mail address, so i can e-mail you the pdf file.
Posted on Nov 05, 2008
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Oct 03, 2012 | Bosch SGS45C02 Dishwasher
Where do i put the salt
Hello Maria,
The salt goes in the salt compartment in the base of the washing compartment. Unscrew the lid of the salt compartment (counter-clockwise), pour in salt until the compatment is full or nearly full then screw the lid back on firmly, but do not overtighten it.
If the dishwasher is new and you are using it for the first time, pour about 1 litre of cold clean water into the salt compartment before adding the salt. If you spill any salt or the water spills over the top of the salt compartment, it will wash/drain away the next time you use the washer.
The most important thing is to only use dishwasher salt. The salt is used for water-softening and only salt sold specifically for dishwashers can be used for this purpose.
The picture above is from a Bosch dishwasher. You may have another brand or model of dishwasher, but the salt compartment will still be in the base of the washing compartment and will have a cap which you unscrew as above.
Hope this helps. If you need further assistance, please let me know the brand and model number of your dishwasher.
Regards,
BElectric
Mar 14, 2011 | Dishwashers
Just moved into a house with fitted NEFF dishwasher, never had one before and no manual left. Where do salts go? Thanks
The salt goes in the salt compartment in the base of the dishwasher. Open the door and pull the lower basket out. You should then be able to see a cap near the front-left corner of the base of the dishwasher. Unscrew this cap (anti-clockwise) and fill the compartment with salt all the way to the top - or with as much salt as you have in the packet - then screw the cap back on firmly, but do not over-tighten it. The salt compartment will (or should!) be full of water and some will spill out as you fill it with salt. This is totally normal and not indicative of any problem.
Do not use any type of salt which is not sold specifically for dishwashers. The dishwasher can be used without salt but it is not advised and may result in a white film being left on your cutlery, glassware and/or dishes.
It may also be possible to provide a user manual in PDF format which you can download, but I would need to know the model number. If you don't know the model number Most Neff/Bosch dishwashers have the model number laser-etched into the stainless-steel at the top of the inner-door or the rim of the washing compartment. Please click on the link below for a guide to locating the model number of your dishwasher. (Neff is a Bosch owned brand)
http://www.bosch-home.co.uk/type-plate-details.html?aftersales=dishwashing&aftersales=dishwashers~16468
Hope this helps. Please let me know if you would like the manual or need further assistance.
Regards,
BElectric
Feb 28, 2011 | Neff S5946 Built-In Dishwasher
I have a Bosch Clasixx dishwasher, it is around 6 or 7 years old. We have had no trouble until now. When we press any programme the usual noise from within begins, but it will not fill with water. We have...
The float switch might be tripping. Pull the dishwasher out (if it's under-counter) and tilt it forward gradually to about 20 degrees. If you see a pool of water on the floor, it means that water is getting into the bottom of the dishwasher underneath the washing compartment.
This can simply be caused by a loose retaining nut on the salt compartment. Unscrew the cap from the salt compartment and you will see a large plastic nut underneath. If it's loose, tighten it - you'll need a large pair of waterpump pliers or stilson for this.
Assuming this was the problem, make sure you empty all the water from the bottom before you put it back by tilting it forwards until water stops coming out.
To stop the problem returning, DON'T over-tighten the cap on the salt compartment. Make sure it's on firmly, but if you overtighten it, it will grip the nut and loosen it the next time you remove the salt cap. If the nut is loose, water can get into the bottom of the washer.
Sep 29, 2010 | Bosch 24 in. SGS43C12 Classixx...
I put detergant accidently in salt section dishwasher
if yo run the dishwasher a few times it should flush it through
Sep 27, 2009 | Dishwashers
Put rock salt in instead of dishwasher salt wat damage has been done if any
Salt? Why are you using salt to begin with? Why are you not using the liquid soaps etc. If your one of those all natural people i use all natural liquid etc. Salt is corrosive and parts that are not stainless steel will corrode quickly!
Jun 03, 2009 | Dishwashers
Dont know where to put the salt and how salt indicator goes off
it should have a dispenser in the bottom of the tub you just need to unscrew the lid
Mar 26, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Jan 03, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
