Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 drive belt replacement
How is the belt changed on the Dyson DC07? I don't have to change it yet, but I'm sure the time will come when that will be necessary. I clean whatever areas I can easily get to on the vacuum cleaner frequently, but fortunately have never had anything break down on it yet. I've had it for several years (at least five), and it's the best vacuum cleaner I've ever owned. There must be some easy solution to changing the drive belt. Seems that when I remove the beater cover, I can remove only one side of the beater easily, but not the side that the drive belt goes around. What's the secret to easily remove the beater bar and access the drive gear inside the plastic motor housing? Even if I don't ever have to replace the drive belt, I'd like to be able to remove it so that I can perform additional cleaning inside the motor housing area. Thanks!
  • faamecanic Dec 07, 2008
    Your link does not work... I have the same problem and Im trying to replace my Dyson Belt on my DC07. For such a well engineered machine, the belt remove/replacement is poorly designed.
  • 372 Answers
Hi.
The other end of the drive belt the part you cant see goes to a clutch.
The clutch unit has 2 belts one is clutch to motor the second is clutch to brush roller.
You obviously look after your machine because you say you have had no problems with belts or clutch for 5 years.
Both belts & clutch can be worked on but its alot to explain so look at this site for service manuals.
http://dysonmanuals.llc.nu/
Posted on Jun 01, 2008
Fiddley yes, but i found that undoing the three screws yep, then ease out both ends of the roller first, then helped with a screwdriver to keep the belt in place i slowly struggled to ease out the old roller. then managed to stretch the belt back over the end and gradually got the new brush back into place. just have to be careful not to push the screwdriver into the belt and damage it. other than that, i couldnt see any other way of changing the brush assembly or accessing the belt partitions.
Posted on Dec 12, 2010
  • 107 Answers
You dont replace the belt you must replace the clutch assembly. It is somewhat difficult and should be done by a authorized service shop. If you can get the part i would be more than happy to explain it to you in a chat session.
Posted on Dec 09, 2008
How to change belt in dyson upright model dc07
Hi there, it's Jack at Dyson.
There are two versions of DC07 - some include a brush bar which rotates all the time when the vacuum is running. And some include a brush control clutch mechanism which allows you to turn off the brush bar for hard floor cleaning. If your machine has the brush control, you'll see the dial on the front of the cleaner head.
If you have a DC07 without the brush control feature, you can replace the belt as shown in our online Support guide: http://www.dyson.co.uk/support/dc07/dc07-standard/maintaining-your-dyson-machine/change-the-belt1/belt-fitting-preparation
However, if you have a DC07 with the brush control feature, the clutch mechanism uses belts engineered to last the lifetime of the machine in normal use. These are not designed to be replaced by the user, and we would advise against attempting to change these as damage may be caused to your machine.
For further advice on having your machine repaired, or to order replacement belts for a DC07 without brush control, please contact our experts directly. You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 30, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Belt change/access on dyson dc07
Hi Geoff,
If your DC07 is a model equipped with the brush control feature, you will not be able to access the belt yourself. If this is the case, please get in touch with us directly so we can discuss this issue further. You can call us free on 0800 298 0298 - our Helpline is available from 7am until 10pm, 7 days a week. Please have the machine to hand when you call.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Jan 30, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson upright vacuum cleaner makes horrendous noise
It might be a simple as changing the clutch belt and the drive belt and cleaning out the brush roll. You can get replacement belts here:
Dyson DC07 Belts
Dec 08, 2009 | Dyson DC07 All Floors Bagless Upright...
Change fanbelt
Here is a link to the belt you need and a manual you can view which shows you how to change a Dyson DC07 Belt.
Dyson DC07 Belt and Manual
Dec 04, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
How do you change a belt on a dyson 07
You will need a spicial belt tool to change the bet on this unit. you can find it on ebey under "dyson spicial bet tool" do not try to use your hands. The belt is very tight and you can hurt your fingers if you get them stuck. let me know if this helps.
Oct 12, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How do i change the belts
you will need to get the special belt tool. they have them on ebey for about $15. enter in "dyson belt tool" into the search engine. don't use your hands as the belt is very tight.
Sep 27, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
2,334 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
