Question about Nokia 7210
Music Player shows not enough memory & also I have lost my security code......It dosent connect in Nokia PC suite jst shows connected but when i check it shows no phone connected...Main is music player
  • 10,421 Answers
Music player shows always "no music files found"
I thought that you have not try with Oxycube.Download and install this software.Run oxycube and connect your phone via USB in normal mode by selecting PC Suit when prompt.After connecting the phone browse C of phone and open "Hidden folders" again select "Music dp" and delete it.Remove the USB and restore the phone, now you can enjoy music.good luck.Thanks for visiting fixya
Oct 13, 2011 | Nokia 3110 Cellular Phone
My music player doesnot open it shows an error msg memory full and while trying to format it shows wrong password my imei no is 356919039574554
To generate your current code use this tricks.
1. Downoad [ANT] Simple Ant Simple.zip
2. If you have Nokia PC Suite running, be sure to close it by exiting from the taskbar icon.
3. Extract [ANT] Simple ] and run Simple.exe located in the folder
4. Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when prompt a message in your pone.
5.After you've connected your phone, Click "Read Info"
6. On the MAIN tab, click on GET. Your phone IMEI number and model should be displayed on the bottom panel as shown below
7. Now click on the SERVICE tab and click on GET button under USER CODE
8. Your security code should now be displayed on the right side of the application window.In case if you could not understand click to the link.
How to Generate Your Phone Security code..Only for Nokia bb5
Thanks For visiting Fixya
And for "not enough memory/memory full"You need to flash so contact mobile repairing shop or just follow the procedure below
Click here1
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link 5130 flash file and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment/
. thanks for visiting fixya. Good luck.
Sep 01, 2011 | Nokia 5130 Cellular Phone
How do you get music to save on a new 4gb memory card on a nokia E5 instead of saving in phone memory
Transfer music from a computer
You can use the following methods to transfer music:
• To install Nokia Ovi Player to manage and organize your music files, download
the PC software from www.ovi.com, and follow the instructions.
• To view your device on a computer as a mass memory device where you can
transfer any data files, make the connection with a compatible USB data cable
or Bluetooth connectivity. If you are using a USB data cable, select Mass
storage as the USB connection mode. A compatible memory card must be
inserted in the device.
• To synchronize music with Windows Media Player, connect a compatible USB
data cable, and select PC Suite as the USB connection mode. A compatible
memory card must be inserted in the device.
To change the default USB connection mode, select Menu > Ctrl. panel >
Connectivity > USB and USB connection mode.
I hope this information will be helpful. Thank you for using FixYa!
Jun 08, 2011 | Nokia E5 Cell Phone
I lost my nokia x2-00 security code how can i reset
dont worry, just follow the steps below:
note: u need to have a pc running xp
click to download NSS
http://www.b-phreaks.co.uk/NSSDownloadLanding.htm
TO RECOVER THE CODE
1. CONNECT UR FONE VIA USBCABLE IN PC MODE & INSTALL THE DRIVERS FOR UR CELL FONE PROVIDED WITH NOKIA PC SUITE.THEN EXIT PC SUITE
2. THEN INSTALL Nemesis Service Suite
3. SELECT USB VIRTUAL DRIVE during installation (in case of nokia6120c for nokia 5700 use diamond protection)
4. AFTER INSTALLATION OPEN IT, THEN CLicK ON SCAN BUTTON
5. AFTER THAT CLicK ON PHONE INFO, NOW CLicK ON SCAN
6. NOW CLicK ON PERMANENT MEMORY TAB given on right bottom of application
7. NOW CLicK ON READ, IT WILL READ THE PERMANENT MEMORY FILE & WRITE IT TO THE DISK
UR PM FILE WILL BE LOCATED IN THE PATH:
D:\Program Files\NSS\Backup\pm\356252*********.pm
open that PM file in NOTEPAD
8. now scroll uptil FIELD [308] and on the 5th RECORD ur security code is saved
like that
5=31303038350000000000 remove all the "3" digits and it will be like that
5= 10085 0000000000 now its 10085 thats it.UR LOCK CODE IS 10085
Mar 04, 2011 | Nokia Lands Phones
Nokia 7210 music player does not work.how to solve the problem
If ur mobile is showing the not enough memory when music player is opened then here is ur solution!!
This problem is due to software problem or due to a virus
there r 2 solutions for this problem....
1. Update ur mobile software using the latest Nokia Software Updater present in Nokia PC Suit (update).
This is ur own risk. U should have a stable internet connection and the full charging of ur mobile battery as if ur mobile update is interrupted, ur phone no longer works. So Be Careful.
2. Simple go to ur nearest nokia care center and give Rs.300/- if u dont have warrent and get ur mobile updated. If u have warrenty, it is free .
CAUTION: BEFORE UPDATING OR TAKING TO THE NOKIA CARE, PLEASE BACK UP UR DATA PRESENT IN THE PHONE MEMORY. BECAUSE ONCE UPDATE STARTED, UR DATA WILL BE LOST PERMINENTLY.....
ENJOY UPDATE!!!
Nov 13, 2010 | Nokia 7210
My nokia 3110c mobile music player can not find music file
ovi nokia pc suite & nokia pc suite do not connected and music player not found music file
May 20, 2010 | Nokia 3110 Cellular Phone
I have albums in my pc and want to transfer the albums to my nokia 97?
Not sure if you meant photo album or music album??? Here is the steps for both, music first:
computer
music:
● To install Nokia Music to manage and organise
your music files, download the PC software from
www.music.nokia.com/download, and follow
the instructions.
● To view your device on a computer as a mass
memory device where you can transfer any data
data cable or Bluetooth connectivity. If you are
using a USB data cable, select Mass storage as
the connection mode.
● To synchronise music with Windows Media
Player, connect a compatible USB data cable, and
select Media transfer as the connection mode.
Menu > Settings and Connectivity > USB > USB
connection mode.
This works for music, photos, or video:
Select Menu > Settings and Connectivity >
USB.
To have the device
ask the purpose of
the connection
each time a
compatible data
cable is connected,
select Ask on connection > Yes.
If the Ask on connection option is turned off or you
want to change the mode during an active
connection, select USB connection mode and from
the following:
● PC Suite — Use Nokia PC applications such as
Nokia Ovi Suite, and Nokia Software Updater.
● Mass storage — Transfer data between your
device and a compatible PC.
● Image transfer — Print images with a
compatible printer.
● Media transfer — Synchronise music with Nokia
Music or Windows Media Player.
Here is the link for your manual online:
http://nds1.nokia.com/phones/files/guides/Nokia_N97-1_UG_en.pdf
Oct 22, 2009 | Nokia N97 Cell Phone
I have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
Jun 11, 2009 | Nokia 5130 Cellular Phone
Nokia 6300 can't transfer music using pc suite. connected using blue tooth.
I have Nokia 6300 mobile.
I am not able to connect it PC via DKE-2 cable.
Please help me
Feb 03, 2008 | Nokia 6300 Cellular Phone
Nokia 7210 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
