Question about Dryers
Manual for Whirlpool 6th Sense AWZ7914AL - Dryers
  • 46 Answers
SOURCE: Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
Posted on May 25, 2009
localwonder
  • 6784 Answers
SOURCE: our whirlpool 6th sense dryer model awz3413 will
HI, check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
2. Door switch / Door switch actuator lever
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
4. Timer
Replace if defective (note: uncommon problem).
**The most common issue here will be a defective Thermal fuse
Posted on Jul 21, 2009
GodBlessU
  • 3513 Answers
SOURCE: what does F7 mean on a whirlpool 6th sense washing
F7 in whirlpools means "Clean the filter”.
The following troubleshooting steps would help fix it. Remove the filter on the floor of the machine, including the metal grill. Press & hold the start button (like you do when you want to cancel a program this will drain the water out of your clogged up drain outlet. Clean your filter and grill and replace it. My guess is that the sensor in the drain (a little glass tube) measures whether the water going out is clean enough to decide that your dishes are now rinsed correctly. If your filters clogged, the water going down the drain is still dirty. After a while it gets sick of trying and stops the machine.
Thank you for contacting www.Fixya.com
Posted on Jul 30, 2009
bozcro
  • 867 Answers
SOURCE: Whirlpool 6th sense dryer gets hot but is not
i think air vent is clogged. check the vent line, remove if you have to, but check outside vent on house wall first. may be even birds nest there.check hole where vent attaches to machine.-plz rate-bozcro
Posted on Sep 20, 2009
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Wanting a user manual for whirlpool 6th sense wfs1071aw front loader washing machine please
go google and type in--operators manual fro whirlpool washing machine model wfs1071aw --- and down load the pdf version
Jun 12, 2017 | Whirlpool Washing Machines
Tip
Tumble dryer not heating how to fix heater, thermostats, Ntc sensor.
We have all these tutorial guides that will help you with your Whirlpool 6th sense
How to clear error codes
How to service a pump unit on condenser tumble dryer.
How to replace belt, motor or bearings.
Tumble Dryer Not Turning, How To Replace Capacitor
We have all repairs guides on these Whirlpool 6th sense Tumble Dryers
http://www.how-to-repair.com/help/tag/6th-sense/
on Jan 21, 2015 | Whirlpool Dryers
I put my 6th sense dryer on for 60 & when i turn it on it says 6 hrs.also can i buy a manual for it please
Can't help you with your first problem, but if you had just Googled Whirlpool 6th Sense Dryer you have found a wealth of information including a free manual. Check here:
http://www.whirlpool.com/-[WEL98HEBU]-1021441/WEL98HEBU/
Jul 10, 2016 | Dryers
Whirlpool 6th sense - pump issue
The drain pump probably just needs cleaned. If you've never cleaned it i can direct you to videos that are step by step. Let me know.
Jan 20, 2013 | Whirlpool Washing Machines
HOW DO I LOCATE THE HEATING ELEMENT ON THE 6TH SENSE DRYER
take the back panel off it is located in the rear.
Mar 19, 2010 | Whirlpool Dryers
My Whirlpool Washing Machine 6th Sense 10kg Dreamspace has stopped washing mid-cycle and has a F09 warning flashing
my whirlpool 6th sense dreamspace has a red ligth lit indicating water tap closed can anyone explain why?
Mar 15, 2010 | Whirlpool Washing Machines
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Jan 09, 2010 | Whirlpool Dryers
May 25, 2009 | Dryers
Dryers Logo
371 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
