Question about George Foreman GP100 Grill
Drip Pan where can i purchase a drip pan for model GP100
PartStore.com
I just ordered one at this web site and it was $10.95 plus $7.95 shipping. With tax, it came to $20.47.
The part number is 21646 listed under George Foreman.
Posted on Aug 08, 2010
The part you have requested is currently not available to purchase online.
We ask that you call 1-800-738-0245 (Monday-Friday, 8:30 a.m. to 8:00 p.m.,
ET) for price and availability. Please have the model number, and date code
of your product when placing the call. Your reference number is 9061882
Locating the model number and date code:
The model number and date code (3 or 4 digit number) of your product is
located on the back or bottom of unit. This may also be located on a
removable label or on the box that the unit was packaged in.
Posted on Oct 10, 2008
Model# kfcs22evms8 kitchen aid fridge- how to clean drip tray? Can't get at it.
Clean Refrigerator Drip Pan, Clean Walls - YouTube
? 2:55
https://www.youtube.com/watch?v=I9YP0iH_zho
Aug 5, 2008 - Uploaded by Handyman Matters
Scheduled Home Maintenance: clean refrigerator drip pan and wipe ... leaking,Kenmore,Sears,Whirlpool,KitchenAid,Roper,10677292790 ...
How to Find the Drip Pan on Refrigerator ' Home Guides ...
homeguides.sfgate.com > Real Estate Rentals & Leases > Get out of Leases
The drip pan on your refrigerator is a receptacle that catches condensation flowing from ... Occasionally you may need to get to the drip pan to clean it, remove a ...
KitchenAid refrigerator drip pan Questions & Answ
Dec 16, 2015 | Refrigerators
I have a Samsung model RF4287HA French door refrigerator. Has anyone had success cleaning the drip pan located at the bottom rear of the refrigerator? I know that this pan can't be removed, but I can'
Hello Derek;
My name is Peter. I am a retired field service refrigeration technician.
In answer to your question, the drain pan is removable. This drain pan is available for purchase. The problem is both Samsung and LG are not service friendly. The drain pan is not secured with fasteners and just lifts up.
However, There is the interference from the seal system (refrigerant) tubing and compressor which prevents you from pulling the drain pan out.
On my service calls with drain pan leakage, I just repaired the drain pan with duct tape an silicone adhesive. Because I could not get the drain pan out with out moving the compressor.
Both, Samsung and LG are the worst service friendly and highest cost for repair.
Jan 19, 2015 | Samsung RF4287HA 28 cu. ft. French Door...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
How to remove and clean grease pan on Vermont Castings model 608SB
The drip tray is accessible from the rear of the Grill. It is necessary to lift up the pan slightly while pulling it out. Or depending on how old your VC grill is, it may be located on the left end of the grill (you should see a small handle). In which case you pull it out and was you reach the end of the drip tray, lift it up slightly to remove it.
TIP: To make clean up of the drip tray easier. Spread a thin layer of Speedy Dry (It's what NASCAR & garages use to soak up oil) on the bottom of the drip pan or tray. You can purchase a bag of it, at any auto parts store, When it comes time to clean the drip tray or pan. Just remove the tray or pan and dump the used Speedy Dry in the garbage. Then, spread a thin layer in it again. Actually, because the Speedy Dry absorbs so well, you'll find that you'll only have to dump the tray or pan occasionally.
Hope this helped you and Happy Grilling!!
Jun 23, 2011 | Grilling
Missing grease drip pan
Call 1-800-233-9054, ask for CONSUMER SERVICE. Tell them your model number, see if they can get the trays for you.
Feb 06, 2010 | George Foreman GR30 Indoor Grill
Need replacement drip pan for model #GRP4P Part # 22619
my proublem is solved. I was looking for a replacement "Drip Pan" for my George Foremen "The next grilleration" grill. The solution is, I googled it. (George Foremenr replacement parts) It sent me to their sight and as you sroll down the page to the bottom you will see comments from other people who were also searching. And some from other who have found answers. You will see a toll free number where you can order your replacement parts for several appliances. My replacement "Drip Pan is on the way.
Apr 12, 2009 | George Foreman GRP4P Indoor Grill
Drip pan
the drip pan is built into the bottom and dont come out ,,, check the drain pipe to make sure its still sticking in the pan ,,,, also check the bottom inside of your freezer, drain may be stopped up and causing water to come out front edge of door / larry
Nov 29, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
George Foreman GP100 Grill Logo
116 people viewed this question
Top George Foreman Grilling Experts
Jaime Hernandez
Steven Clarke
Steven Clarke
Are you a George Foreman Grilling Expert? Answer questions, earn points and help others
