Printer does not print. Error message:- "The printer is off line. Check that the printer cable is connected and printer power is on". Printer cable is connected and power is on. Computer and printer is wireless.
  • Lkraus411 Jun 08, 2008
    Printer returned and replaced.
    Thank you
Printer was replaced
Posted on Jun 03, 2008
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
Error 0xc05d0082
Remove cartridges,switch off the printer, dis connect usb cable & power cable.. wait couple of minutes..powering it wait till message appears for consumables.. install consumables., install usb cable.. check...for message.. Remove CMOS battery mounted on formatter wait for couple of minutes, power it then check..
Jan 31, 2012 | HP Photosmart C6100 All-In-One Printer
I have a problem with my hp printer deskjet model k110a evrytime i print any document and pop up on my screen is """"you cartridge are have damaged or failed""""...
Please try the below steps...
  1. While the printer is ON, remove the ink cartridges.
  2. Unplug the power cable from back of the printer while it is ON.
  3. Wait for 60 seconds.
  4. Plug in the Power cord into the printer and wait while the printer powers on and is silent.
  5. Install the cartridge one by one and check for the error message.
  6. Replace the ink cartridge.
Jul 09, 2011 | HP Office Equipment & Supplies
I put 2 new printer cartridges in and got the effor Oxc18a0101. What should I do? My printer is an HP Photosmart D7160. I've looked at some solutions on line, but they refer to typing numbers,...
Hi Karen, This likely is either due to Bad/Expired Printhead or it could be defective printer ( hardware failure ). However you can give it a try. Follow the steps below and it should solve the problem, else we need to consider it could be defective Printhead or printer hardware failure.
The Photosmart D7160 does not has "*" and "#" because it is not a fax capable printer.
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
The error message 0xc18a0001 "Ink System has Failed" is now gone
Regards,
Ron
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
May 17, 2011 | HP Photosmart D7160 InkJet Printer
My hp c6400 is connected to my pc via a usb cable but when i try to print their is always a message that says, "your printer is offline". what should i do?
1. Double check the power and usb connections in the back of the printer. 2. If securely plugged in, unplug the usb connection, wait a few seconds and plug it back it. 3. If printer is still off line, right click on the printer and delete it. 4. Unplug the USB again, wait a few seconds and plug it back in. 5. The printer should reinstall and reappear in your printer list.
Mar 03, 2011 | HP Office Equipment & Supplies
Trying to print,getting message "printer
Hello
Check Cable, then re-install drivers.
Good Luck
Mar 02, 2011 | Canon Office Equipment & Supplies
Hello, when i try to print from microsoft works or on line, the message "Printer is offline. Check that the printer cable is connected and the printer power is on". I have...
Check under "printer and faxes" on Windows XP. In the printers list look for your printer and right click on the printer. On the little menu when appear, see if a 'Printer offline" is checked.
Nov 26, 2010 | Brother HL 2140 Laser Printer
My HP Photosmart C4280 all in one printer will not print...can you help?
Do/did you get any error messages?
Check that the printer is online and check the printer queue (Devices and Printers in Win7). Try a new USB cable and plugging the printer into a different port. If you have a print server or USB hub, try connecting directly to the computer.
Reset the printer by unplugging it and the USB cable. (If files are built up in the queue and the printer is online, try deleting them. If they don't delete, you need to stop and restart the printer spooler. In any version of Windows from a command prompt window, type "net stop spooler" without the quotes and hit <enter>. On the next line type "net start spooler" again without the quotes and <enter>. Restart the computer.)
Other issues are possible if there are any error messages that you don't mention.
I hope this helps.
Apr 12, 2010 | HP PhotoSmart C4280 Laser Printer
Error message 0xc18a0201
try to reinstall your printer and if the error message show up again try to check your printer to the HP customer care mybe the problem from your board printer
Apr 09, 2010 | HP Photosmart C5180 All-In-One InkJet...
43 people viewed this question
jasbo
jasbo
