Question about Philips Magnavox 27MS343S 27" TV
Ok where do i put the solder
There is a light blue paper in between the the black retangle and the alumunim verticle thing with 9 pegs coming out where do i put the solder!!
  • Philips Master
  • 8,617 Answers
On the other side of the circuit board where the pins are solderd to the circuit board. Be very careful soldering the pins because if you bridge the pins together with solder you can damage your set badly. i would recomend just heating the solder thats there to reheat it and not add any more unless your skilled on soldering with pins located close to gether as you can damage the set worse if your not careful.
Posted on Jun 01, 2008
Just installed a 1200 all in one HP printer and it goes through the motions of printing but nothing is on the paper, i have deleted, reinstalled, check every setting possible, done everything that the...
Many a times the cartridges get empty.There is ink in the cartridges,this ink gets over or many a times dried up.Remove the cartridges and see.There will be a steel color nozzle at the base of cartridge,from where the ink comes out.Touch the tissue paper to that base and see,if there is ink coming out.Actually the ink should come out.There will be two cartridges in the printer.One black and one tri-color.On black cartridge when you touch the tissue paper you will get black ink on tissue.On tri-color cartridge when you touch tissue on its base you will get three colors,that are yellow--- blue and pink.( In printer language its called cyan--- yellow---magenta color).If there is ink in the cartridge then it should print,If you have replace the cartridge,then on its base there is a blue color tape.That tape has to be removed from its base.If the tape is not removed the cartridge will not print.-------- One more thing.Before doing any thing.Just do a self test and see if the cartridges are working. The procedure of self test is as follows:--- " 1) Turn the printer on.2) The power on green light should be steady green,not blinking green. 3) When its steady green at that time.Press the cancel and color button both together. 4) By doing this the green light will flash,and printer will take the paper. 5) On that paper the self test will get printed.But if the printer takes the paper and it comes out empty /blank then its cartridge fault.But if the self test is getting printed,then yes its confirmed that there is communication fault between printer and computer.In this case,replace the usb wire.Try new brand usb wire and see if that is helping.One more thing.When you install the printer driver.At that time never keep the usb wire connected between printer and computer.Only keep one side of usb connected to computer tower.In between the installation procedure.The message will come up on your computer screen" this message reads,connect the usb wire to printer.At that time connect the usb wire".As you connect the usb wire the message will come up on your computer screen.The printer is detected.If this message comes up then only your printer will work.If this message does not comes then,there is any of the three things faulty,that is usb wire,the usb port on printer side or usb port on computer side.If usb wire is faulty you can replace this wire with new and check.Its not a costly wire.But if any of the ports are faulty,then this ports are internally soldered on the main board.This ports needs to be re-soldered.This can be done by any printer/computer repair tech.Its hardly a 10 minute job to re-solder loose usb port. ------------- Try this troubleshooting procedure.This will help. Thanks.Helpmech.
Jan 27, 2011 | HP PSC 1210v All-In-One InkJet Printer
I instaled a timer Leviton 5-10-15-30 to the bathroom fan. I put everything in the correct place, balck with black, blue with the black that goes to the fan, white with withe and green to the ground. The...
1) To test the timer, put it on another Load, for example a light.
2) Also you can test your wires.
Take wire nut off Black-black connection and test to bare ground >>> tester should light up.
Next take wire nut off Black-blue connection and test to bare ground >>> tester should NOT light up until push button is activated and countdown begins.
3) Another thing to try is reversing the blue and black wire, just to double check your wiring.
Jan 04, 2011 | Leviton Hardware & Accessories
I have a 93 Ford Laser hatch back and I need to know the radio wiring color codes for the wires that plug into the back of the radio-cassette. 1)Orange-green tracer 2)Orange-black tracer 3)Grey-green...
OK this is what I did: First I soldered a wire each end of a 1.5v battery. I then bared the other ends of the two wires and tinned them. Then I touched the wires coming from under the dash in pairs until I heard the resultant sound coming from a speaker. This then told me the position of each speaker in the car. From there it was just a matter of noting the color codes for each pair of wires and from which speaker they came. My Gregory's Laser KH manual had wiring codes, but entirely different to my vehicle. Also there is no indication of what color matches what letter code! Cheers. Gerry
Dec 19, 2009 | Philips Car Audio & Video
Yellow light on ps3
The yellow light is caused by the PS3 console overheating.
Over time and many thermal cycles one of the connections to the two major chips on the PS3 motherboards will break ( cold solder joint ).
The only way to fix this is to perform either a reflow or reball to the problem chip. This consists of heating the chip to melt the solder, when it cools the solder will "reball"; fixing the connections.
We perform this service for $79.99 and offer free shipping for web orders. GATpro Repair
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
7130 black and white copier
ok so many things can couse this problem.
if it is total dark black and the scan light is there try to trace
1.too old the exposure lamp so that it brights low
2 the mirror on the scanning assembly may be one is missplaced eccidental or brocken.
3. the blockage of light by black pastics cover infront the lens
4. the heavy tonesof tonner powder is contacting the inner most mirror in optics section
5. the died preexposure lamp or its suply voltage is missing
6. the dc control board is mulfunction
7.the reflector mirror just at the scan lamp
8.excessive toner suply bias voltage biasing the toner catridge unit
9 too old the exposure lamp
tyr look on these and if it solve the problem pls vote me and if still the problem exsist let check another things i wish you success.
Oct 02, 2008 | Canon NP 7130 Black and White Copier
Black line in screan
Hi sony with line is a verticle ic la7838 is one of the verticle ics that go in some sony . or cold solder joints on ic if you tap it and picture come back
thanks DOCTOR VIDEO.
Apr 27, 2008 | Televison & Video
Philips TV Model 32DW6557/05 Screen Problem
hi it sounds like a capacitor in the verticle circuit located on the main board. it is near the verticle ic. the verticle ic also could be bad the cost is around 85 dollars for a tv shop to fix. sometime a cold joint could be found around vert ic. a soldering iron is required with solder.tap the side of tv if picture comes back it is just cold solder joint.
thanks Doctor video
Apr 25, 2008 | Televison & Video
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Zenith model SR3587 Picture too wide
there are a couple of coils that are for pincussion and width that get cold solder connections on them and sometimes will blow out the curcuit. Maybe its not to late to resolder them? Good luck
May 19, 2006 | Zenith Z35X21D 35" TV
Philips Magnavox 27MS343S 27" TV Logo
24 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
