Question about Nokia 6300 Cellular Phone
Power on automatic shutdown - Nokia 6300 Cellular Phone
    Sergeant:
  • 172 Answers
Replace battery or reprogram
Posted on Oct 12, 2010
Automatic shutdown
Check the CPU Fan and make certain it is functional. Some computers do an auto-shutdown when the CPU reaches a certain heat ratio upon starting. Make sure the power conncetion is on firmly.
Jan 13, 2014 | HP Computers & Internet
What is pcm asd circuit
PCM is powertrain control module. ASD is automatic shutdown. The PCM operates the Automatic Shutdown relay and fuel pump relay. The ASD relay supplies power to the fuel injectors and ignition coil. The fuel pump relay connects power to the fuel pump.
Oct 07, 2012 | 2004 Dodge Stratus
What is ASD RELAY
The power supplied to the fuel pump, ignition coil, fuel injectors, and parts of the power module is controlled by the logic module through the Automatic Shutdown Relay (ASD); the idea is to shut off fuel pressure and the ignition systems when the key is turned off to prevent fires, dieseling, and other problems.
The ASD relay is closed (allowing power to flow through it) when the ignition is first turned on. If the signal from the ignition reference is lost while the engine is running, or if the turbo boost pressure reaches and exceeds the over boost cut-off point, the logic module cuts power to the ASD, which in turn removes power from the fuel pump, ignition coil, injectors and those parts of the power module. This causes the engine to shut down.
Failure of the automatic shutdown relay is often shown as inexplicable stalling or refusal to start.
Mar 09, 2011 | Dodge Caravan Cars & Trucks
Dns-323 automatically shutdown few seconds after startup
had you found a solution ? i'm front the same problem :(
Aug 01, 2010 | D-Link Dns 323 2-Bay Network Storage...
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
Aug 25, 2009 | Acer Extensa 5620-4020 Notebook PC
It will not even turn over, has power to starter, but no power to ignition fuse next to battery, thought maybe automatic shutdown fuse, but dont know
Take a 1/2 drive socket set and put it on the lowest pulley or crank pulley and try turning the engine over by hand to make sure you have not sized the engine.
Apr 20, 2009 | 1994 Jeep Grand Cherokee
When power cable is plugged in, If i try to shutdown my laptop it shutdowns and starts automatically
access the system bios at startup and change the automatic restart after a power outage option
Dec 30, 2008 | HP Compaq Business nc8000 Notebook
Unable to shutdown NEC versa S3300
It assume to be problem with BIOS, check out the Bios Power Setting and Boot Priority, by pressing DEL, ESC or Function key usually used.
And change them and then try.
2 method - try after unplug external devices and found which one is conflicting due to which it going to automatically start when you shutdown.
Thanks,
Ellin
Nov 04, 2008 | Computers & Internet
Automatic shutdown
You either have two issues . The heatsink Fan needs replaced ( it will shut down to save you from burning out the chip ) Or possibly the power supply has an issue . More than likely is the Fan for CPU .
Please make sure you mark my correct solution for your motherboard
Thank you
Aug 05, 2008 | ASUS M2N-MX Motherboard
Nokia 6300 Cellular Phone Logo
82 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
